Question about Singer 3116 Simple
I can thread the needle but not the machine. How do I thread the machine?
    Genius:
  • 1,116 Answers
Here are the guides - http://www.singerco.com/resources/threading.html
You can also download a free manual for the 3116 at the same site.
Posted on May 15, 2010
My Elna 730 pro. The thread is fraying and breaking.
Be sure to install a brand new needle that is recommended for the thread and fabric you are using.
Check to make sure the machine is threaded correctly. Remove the thread and rethread from the beginning.
Could be old/bargain bin variety thread. Use only fresh, good quality thread.
Another possibility is an incompatibility of needle, thread, fabric. Make sure the thread is not too small for the needle eye which will cause thread fraying. If the fabric is coarse or dense, it can also cause the thread to fray--a needle with a larger scarf (ie top stitch needle) will help protect the thread during the multiple times the needle pierces the fabric. In rare instances, the needle may be defective or there machine has a burr somewhere that is catching and shredding the thread.
All About Needles
Schmetz Needles Needle Guide
It is important to install brand new needles frequently, ie every 8 hours of sewing. The needle is a very inexpensive item but could be very expensive in frustration, damaged fabric, and possible machine damage.
May 09, 2017 | Elna Sewing Machines
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
I am using a finesse 356 sewing machine and the thread keeps on breaking off at the needle. What could be the problem?
Could be threaded wrong. Could be tension too tight. Could be a bad needle. Could be bad thread (avoid old thread or bargain bin thread). The fabric, needle, and thread may not be compatible, ie the thread is too large for the needle's eye, could be incorrect thread for the fabric, the fabric may be too coarse and is wearing the thread and causing it to break... There could be a burr or nick somewhere that is catching the thread. The thread could be hanging up somewhere in the thread path on the way from the spool to the needle causing it to break when it reaches the needle.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwi04JrRs-_NAhWKPiYKHaccBmwQFggzMAI&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles Understanding of Sewing Machine Needles Coats Industrial
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Sewing Machine Problem 1 Thread Breakage
Jul 12, 2016 | Sewing Machines
200 thread breaking
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3. Needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and bobbin thread are not set under the presser foot before sewing
6. The thread is either too heavy or too fine for the needle
7. The needle is not the correct one for the fabric being sewed
8. Check for burrs on the needle plate
Dec 23, 2015 | Sewing Machines
How do i fix my machine, it's breaking the top thread all the time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 28, 2012 | Sewing Machines
Always thread breaks
try these suggestions
Oct 30, 2012 | Janome 6019QC Mechanical Sewing Machine
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
Top thread breaking especially when machine in reverse.
try this
The machine is not threaded correctly--rethread the machine
The thread tension is to tight--reduce the thread tension (lower number)
The thread is to thick for the needle--select a larger needle
The needle is not inserted correctly--remove needle & reinsert the needle (flat side toward the back)
The thread could be wound around the spool pin
The needle is damaged--replace
Some needles & thread are not compatible--try this
Nov 03, 2010 | Singer 8280 Mechanical Sewing Machine
Needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Feb 18, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
