Question about Ricoh Aficio 450 Copier
I have problem with my copier aficio 450,sc548 appear,please help me solve this error
  • 1,110 Answers
SC548 is a fusing unit installation error. The machine can not detect the fusing unit for some reason. Did you have the fusing unit out of the machine? Like to remove a paper jam? In case you do not know the fusing unit is the part that gets hot. Located right before where the paper exits the copier. It comes out the front of the machine when you have the front door open. If the front door is open it is in the upper right corner and should have a blue knob on it. Make sure this unit is all the way in. You also may have a wiring or connector issue causing this as well.
You will have to enter the service mode to reset this code.
CAUTION: Do NOT mess with this service mode in any way other than the specific function I give you. Doing so could result in damage to your machine!
Enter SP (service mode) by pressing yellow C button, then press 1 0 7 on numeric keypad and then hold down the orange C button, display will change and then from the menu select "copy SP" then type in 5801 and press #, then press "execute". Turn power off and back on. If the code is gone and the machine works then your fine. If it comes back you will need to call a servicing company and have them repair the machine.
Good Luck and Thank You for using Fixya.
Posted on May 15, 2010
  • 155 Answers
SC548 means that the machine can not detect your fixing unit.try to pull out and insert again your fixing unit.
  • 903 Answers
Follow Wheatlandsvc's advice to fix the sc548, but the program in Service Mode you want is SP 5810. Hit Execute and then reset the copier, and if there is no other problem it should come up to Ready (assuming you have the fusing unit in place).
Posted on May 26, 2010
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Copier mp3500 rex rotary ,i want to remove the authentication ,it displays sc548 contract serial no of march M2772901444
This a fuser (hot section) error code that need you to enter service mode to clear, -Carl
Jun 04, 2010 | Ricoh Aficio 450 Copier
Functional problem
Press next buttons by order :
1. press the yellow button [C] (cancel)
2. press the follow number on the number pad 1-0-7
3. press and hold the red key [C] (stop) until on the screen appear service menu.
After the service menu will appear turn off and then after 5 seconds turn on the machine from the main switch which is located down in the left corner under the front door.
Dec 14, 2009 | Ricoh Aficio 450 Copier
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Error sc548 aficio 1022 ricoh
Poor connection of the fuser, and the code will need to be reset in service mode.
Jul 17, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh aficio 450
WHAT ERROR CODES APEARED TO YOUR COPEIR?
Feb 26, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
628 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
