Question about Haier HLH376BB 37 in. HDTV LCD Television
My screen was dented and crack. I have some pitcure but it shows a rainbow like effect. Every thing beside that is o k, can the screen be replaced....
  • 3 Answers
I have seen this problem numerous times at my job. Unfortunately the cost to attempt to repair this issue far exceeds the value of the television. Its cheaper just to purchase a new one.
Posted on May 15, 2010
Testimonial: "THANK'S ALOT"
Has anyone yet come up with a fix for small dents on stainless steel appliances?
I saw something on YouTube the other day for small dents in car bodies. The pour a full kettle of boiling water on the dent and it popped right back out. Something to do with the metal expanding.
The other thing you can do is rub all the stainless steel with baby oil, which might hide it. Finally, you can hide it with fridge magnets or pictures of the kids.
You should be getting some discount, or if it really bothers you, get it swapped for a perfect one.
Feb 29, 2016 | GE Refrigerators
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
Cracked monitor
replace screen cost 20 dollar
Jan 05, 2013 | Nikon Coolpix S1 Digital Camera
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Spiderweb effect on lcd screen
only solution is replacing entire screens. very expensive, try finding manufacturer on internet.
Dec 02, 2009 | Televison & Video
So i turned my ipod on this morning and about a third of the screen has these lines of color going down it, there is a dent at the very top of the screen and a crack going across part of the screen, it...
What happened is the LCD has cracked. Normally the molecules in an LCD are lined up parallel to each other. When an LCD (Liquid Crystal Display) breaks the liquid between the two sheets of display glass spread causing the molecules to loose that parallel orientation. That's where you get the colorful display. You can press on an LCD and cause this to happen without any damage (though I wouldn't recommend it to often).
Second explanation.
Rainbow bright has a thing for you and she left you a "Rainbow Message" on your Ipod. She just hit it a bit too hard with the "Rainbow Wand" ":)......
As long as you don't care what it looks like then don't worry about it. In ten or twelve years when you spend all the money you saved by not buying the next greatest gadget to come out on a ski vacation in Whistler/Backcomb. You can call all your friends and ask them "HOW YOU LIKE ME NOW"?
Before you buy a new one just remember to look around on-line for used or replacement parts for yours. They are out there and with a little bit of effort you can change out your screen.
I have an Ipod 6 gig mini that has parts to three different mini's in it. (Hey I'm a little hard on my gear. Plus working on a solid plate steel floor doesn't help.)
Hope this helps.
Oct 27, 2009 | Apple iPod MA446LL/A MP3 Player
Screen was pushed in, takin covering/surround off and fixed screen, replaced covering/surround but colour not right, can see rainbow effect on pitcure. is there a certain way screen must go to transform...
If this tv has a feature called magic focus or perfect focus which is a button inside door that flips down on the front, then it has sensors on the inside of the screen. When it was pushed in, these were probably messed up and will cause a poor picture. It may be difficult to get those realigned. Magic focus will not work right until they are realigned.
Oct 23, 2009 | Toshiba 42H81 42" Rear Projection...
My screen stopped showing display
youur screen das damaged go at service sentre and vote me
Apr 04, 2009 | Motorola Mobility RAZR V3
Screen is damaged - is it replaceable?
While actually replacing the screen is a simple task, the cost of the replacement could eassily be the same or close to a replacement set. Check in your area for the cost of a replacement panel. I suspect the cost will be too high to be practical. It loks like this may end up in the trash.
Sorry about the bad news...
Dan
Jan 27, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Vertical rainbow on right hand side of screen
Sounds like u have a crack in your LCD panel. Not much u can do except order a replacement panel. If u press on the panel it will rainbow more. Only thing u can is replace it.
Aug 23, 2007 | Philips 15MF605T 15 in. LCD Television
Haier HLH376BB 37 in. HDTV LCD Television Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
