Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony Wega keeps shutting off and restarting
Just started a few moments ago. Sony Wega 60" keeps shutting off and restarts
5 Suggested Answers
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
ladywinn
  • 5138 Answers
SOURCE: Sony grand WEGA 60" with tiny blue dots all over
Sorry but you have a BAD light engine Sony is well know for this part to go bad quick, I think your tv is DLP?
Posted on Sep 18, 2009
SOURCE: Blue Blob on 60 inch WEGA
http://sites.google.com/site/sonylcdrptvproblems/ This site will have all the info you need to fix this problem, or have sony possible replace your TV with a newer model as long as you have your invoice.
Posted on Feb 27, 2010
SOURCE: My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Posted on May 19, 2010
My Sony Wega, model# KDF-E60A20 keeps shutting off for minutes at a time. The green power light stays on , no flashing. A few seconds before it turns back on ther is a click and a power up sound. Does...
Just replace the bulb first. They last a long time, but after a while if they don't simply blow, they will start to shut off for short periods, then restart. The odd thing is the whole set shuts down too, so something else also may be happening, maybe to do with the temperature control circuitry, that causes a full system shut down. My TV repair man said try this first before I bring the unit in for a diagnostic. Transporting them is not an easy thing to do, given the size of these TVs. I originally bought 3 extra bulbs in 2005, and now used up the last one, and I use the TV a lot.
Apr 25, 2011 | Sony Televison & Video
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Picture on for 1 minute then off for 1 minute and it keeps doing this
It might be time to change the lamp if you haven't done that in the past year or so. It sounds like the emissions of the lamp are weakening causing the cycling of the TV. Please take a few moments to rate my answer. Thanks...
Nov 19, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV goes to green, sound stays on a few seconds then TV shuts off.
Sounds like you have a bad picture tube. More than likely the CRT could be shorted, which would cause the set to shut down.
My first advise would be to power up the set with an isolation transformer with the voltage about 60% approx. 72 Volts AC, and monitor what happens when you increase the voltage slowly.
If the set remains on at 60 -70 %, then when increased to 90 - 100% it shuts down, you have something drawing too much current ( which could be the CRT )
Sep 14, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Flooded starting
I have the same truck, my motor went south blew the head gaskets, but right befor that i was having the same issue. It qwas a bad spark pulg and a O2 Sensor, i just changed the plugs and it was all good after that.
good luck
Jun 18, 2009 | 1993 Isuzu Trooper
Sony Grand WEGA KF60WE610 60...
The first place to start is to change the lamp
May 11, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
