Trying to find manufacturer of digilogic to tune dvd recorder into tv
Hi
Am trying to find out who manufactures digilogic tv. Am trying to tune in dvd hard drive recorder to digilogic tv but cant find manufacturer on the list so dont know which one it is. Any suggestions please?
    New Friend:
What is the code for Digilogic television, Model number
D14PTV1
Posted on Mar 11, 2010
    Genius:
  • 1,694 Answers
Try www.remotecodelist.com ...............T.
Posted on Mar 30, 2008
SOURCE:
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can not get the DVD player to record to our new LCD TV. Worked fine with the older CRT model. It will play OK. Do I need an upconcertter to make this work?
What kind of connection (wire) are you using to connect the DVD player to the TV? Is it composite (RCA, yellow), component (3X RCA, blue, red, green), S-video (Mini-DIN, like a computer keyboard or mouse connector), DVI (Like a wider computer monitor connector), HDMI (Wider and thinner but like a USB connector)?
Apr 15, 2008 | Televison & Video
Unable to tune my liteon dvd recorder DD-A300 to a panasonic tv
I'm a bit confused about what you are trying to do? DVD recorders don't tune in to TV's anymore. They output the signal to the TV via a connector such as HDMI. To record the recorder will need an aerial feed etc, which can be split using a splitter between what feeds the TV and Recorder.
Dec 20, 2012 | Televison & Video
Can't play or record anything, or even turn the machine on.
I can help unlock your digilogic dvdvcr2 from safe mode.
The steps are written out here.
I hope that helps.
Dec 29, 2008 | Televison & Video
I need a manual for a Digilogic DVDVCR2
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The above link will direct you to the manual.Please do rate if we could solve your problem.Thank you.
Sep 07, 2008 | Califone International DVDVCR200 DVD...
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
533 people viewed this question
Top Televison & Video Experts
Ekse
