Question about Car Audio & Video
Need schematic for mtx thunder 5400xw - Car Audio & Video
  • 5,807 Answers
Hi
cawarr,
Schematics for your unit may not be available on line, but will try
to help you , if you need to work on component level.
The faults are typically in the output or driver stages. You'll also see a
lot of broken and shorted inductors.
Bad op-amps have been a problem as well as bad solder connections on
the small transformer in the audio section
When troubleshooting these Class D amplifiers you may need to
measure first the supply voltages on the Main Amplifiers.
It could be at least +25 and -25 ( sample only )
and the Op amp supply , can range to +12V and -12V but no more
than + 15V and -15V.
Here is tip , should you wish to troubleshoot more:
http://www.fixya.com/support/r4008719-diagnose_not_having_audio_right_channel
the unit and component may not be the same as yours but the
principle in troubleshooting is the same.
How to solder boards properly
How to use a multimeter
Please give us more details on your unit as to assist you further
And give you more possible solution to solve your problem.
Thanks in advance for choosing Fixya for assistance.
Hoping to have a response from you , as i prepare the possible
solution to your problem.
Regards,
palaboy
Posted on May 15, 2010
  • 2 more comments
  • cawarr May 15, 2010
    Please advise what the component part numbers are for REC902, FET903, FET901, FET904 and FET902
  • Rommel Cana
    Rommel Cana May 15, 2010
    here are the possible replacements:
    IR_IRF1010EZ
    IR_IRF3205
    IR_IRF3205Z
    IR_IRFZ34N
    IR_IRFZ44N
    IR_IRFZ44N
    IR_IRFZ48N
    IR_IRFZ44
    IR_IRFZ46N
    IRF-540 and IRF-9540
    P12P10 and a STP36N06V
    But the best replacements would still be... what is printed on the MOSFET , unless it all blown
    How to test MOSFET
    Thank you for your input. Fortunately, I could read the number off one of the mosfets i.e. 60NE06-16 so I will replace all four as they are cracked in half. The REC902 is not the same device, it is physically different and the number is burnt off, please advise.
    Please also provide me with a description / part number for C912 as it is also burnt.
    A schematic sure would make this a lot easier.
    Thanks.
  • Rommel Cana
    Would it be possible that you describe a little about " REC902 " ?
    a ) Is it on the power supply or on the main amplifier?
    Have all the Power MOSFET ( Main Amplifier , not the power supply ) removed,
    and measure voltages on the rails of the Main Amplifier.
    If there is none , then most probably it is on the power supply
    Use the Audio Input ground of the amplifier, not the negative or chassis of the amp , as your
    reference ground , when measuring for voltages.
    The supply may rise up , and you may need to measure the DC output of each amp output.
    If , there is more than 0.7V , have to trace for bad driver transistors also.
    Do these before replacing the Power MOSFET to avoid damage on the new replacements.
    A good amplifier never produce an over of 0.7V on its output!
    If there is no output voltages on the power supply ( like +25V and -25V , sample only ), then
    most probably, you need to start with the power supply before replacing the bad Main Amp Power
    MOSFET.
    Failing to do those, will just blow again your new MOSFET.
    Use a regulated power supply ( 13.8V at least 6 A ) when troubleshooting the amplifier or otherwise
    a 12V battery, never use a 12V charger for battery as a power supply.It will only add damage
    to the power supply circuits.Use a low power fuse rating since the Power MOSFET are removed.
    STP60NF06FP
    STP60NF06
    60NF06FP
    STP60NF06FP
    STP60NF06FP STM 2950
    Trans MOSFET N-CH 60V 30A 3-Pin (3+Tab) TO-220FP
Ayuda con el MTX THUNDER 895
Ojala que no pagastes mucho por el. SI tienes un tecknico cerquitas te lo puede reparad barato. Si lo tienes que mandar a MTX no conveine.
Feb 19, 2014 | MTX Thunder 5-Channel Amplifier 895 Car...
Schematics
Maybe MTX can provide a schematic.
Nov 27, 2013 | MTX TA4501 Thunder 4501 MonoBlock Car...
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
Need manual for mtx audio thunder 4501
Hello
Get into this link. You can download the user manual to your device from here. OK.
caraudio.manualsonline.com/manuals/.../mtx_audio/mtx_audio_car_s
Jan 13, 2012 | Car Audio & Video
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Diagram x1000d
http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/XT_1000XD_InstallSheet.pdf
THIS LINK WILL TAKE YOU TO THE SUPPORT PAGE FOR THE 1000XD. IF YOU WERE REFERRING TO THE SERVICE MANUAL OR SCHEMATIC OF THE CIRCUIT BOARD, THEN YOU WILL HAVE TO CONTACT MITEK AT 800-225-5689 AND ASK FOR MR. DABBAS. LET ME KNOW IF YOU REQUIRE FURTHER ASSISTANCE......V
Jan 13, 2010 | MTX X Thunder 1000XD Car Amp
Mtx thunder 2300 amp..want schematics please
YOU CAN CALL MITEK CORPORATION AT 800-225-5689 AND ASK FOR JAD DABBAS AND HE MAY BE ABLE TO GET YOU THAT SCHEMATIC. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE......V
Oct 29, 2009 | Car Audio & Video
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
Sep 09, 2008 | MTX Thunder 81000D Car Audio Amplifier
Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Feb 07, 2008 | Car Audio & Video
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
