Question about Fantom Drives 120 GB Hard Drive
FANTOM Titanium TFDF12072 120GB 7200 RPM External Hard Drive not recognized any more.
  • 4,924 Answers
Wow...so ..first to check is the bus...if you use it on a usb ...probably it is a lack of driver or the computer just messed the driver ...so ...plug it ..and run the add new hardware feature from the control panel to see if it founds it ...choose already added and check it in the list ..
Also take a look into the device manager (right clck on my computer /properties../hardware ....Here you should be able to see t in the list ...if not .., right click on computer and choose to scan for hardware changes....this will scan for devices and show you the device even if it is not installed..
also ..it may be using a raid driver that it is not installed on your computer cause you didn't used it ..do ..go to bios..default the system by selecting optimal factory defaults ..and after that save changes by pressing F10..
restart and insert the motherboard drivers disk and install the raid driver from the list ..(I sow that some of them are on Ieee 1394 fire-wire...so ..installing a driver for the IEEE 1394 bus can be a option you have to get in mind..Just search for it on the motherboard manufactirer site...but it is built in windows since Xp..and defaulting the system ..probably make it functional..if it is the case..
if nothing works...open it and check the power supplies for each unit in part if it is multiple (hdd) and be sure they are plugged well and functional ...You should hear them work ..
Posted on May 15, 2010
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 30, 2010 | Fantom Titanium 250GB External...
Computer not recogning my hard drive. I've tried both USB ports. Light does come on.
Windows update should fix it.
Go to start, program, windows update.
Run all the updates.
If you have dial up then you need to contact Microsoft for the updates on CD rom.
Dec 21, 2009 | Fantom Titanium USB 2.0 80GB 7200rpm...
Unrecognized FANTOM HDD volume
have you try it with another system? if no try it and if it continues then try scanning it with antivirus program installed in your system. if all this no success then get and another okay.
Nov 11, 2009 | Fantom Titanium Hard Drive
My PC doesn't recognize the external drive. I think PNP is working properly because other devices are immediately recognized.
you need to go to delet all the drivers that you have by going to control panel, system, device maanger and delet the drivers reboot and the system will start reading asll your drivers again and it should work..
Nov 07, 2009 | Fantom Titanium Hard Drive
External Hard Drive won't show up!
if its usb then i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 19, 2007 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
Fantom Drives 120 GB Hard Drive Logo
282 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
