Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Does this tv need a converter to recieve digital with an antena
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
I have a Hitachi 50 in plasma. I am using an indoor antenna for local programing only. My tv guide says no listings. I finally had it up and running for a few days but now it is gone again
Buy a better design antena like a digital antena design for a better and stronger to recieving Free DTV broadcasting tv recieving signal.Rescan for free DTV broadcasting signal again,will get it for good this time.Tries websites like Amazon.com,Ebay.com they have many types of digital antena tv design to buy.
May 09, 2011 | Televison & Video
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Analog to Digital converter
Ur tv a LCD or Plasma tv?No,LCD and Plasma Tvs have a Digital tuner inside the tv to recieve free air DTV.Not require a Digital coverter box,if u have a LCD tv or a Plasma tv.U must have good antena thought like a roof or a digital antena,so ur tv picture don't cut in and out very often.
May 29, 2010 | Olevia 332V LCD TV
Can you get a signal without cable or a converter box
Yes,if ur tv is a LCD or a Plasma tvs.It have the tuner inside already it will recieve the digital tv free air brocast.Must have a good antena though like a roof antena,or a digital inside antena.To get excellent signal.So it would cut in and out the broscast of the free digital signal.
May 25, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
I have the converter box i have a plasma samsoung do i nstill need a antenna
Yes,u need a good antena,like a digital antena or a roof antena to recieve good free air DTV signal.U don't need a converter box,because ur tv is a digital tv.
May 04, 2010 | Samsung LN32A330 32 in. LCD TV
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
Why does my digital TV image fall apart into pixels and the sound breaks up - when I switch the digital box to TV antenna, the reception is ok, just not so sharp as with digital conversion. Is it a problem...
Tries directly to a good antena,like outside antena.or a digital antena,no need for any box,new LCD Flat screen tv have an converter in side,no need the box help only old CRT tv have no converter board in side.
Oct 31, 2009 | LG 42LG50 42 in. LCD HDTV
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
