Question about Microsoft HannsG HU171D 17" LCD Monitor
What buttons resets monitor to factory settings as screen is very blurry
  • 11,361 Answers
For best picture, you need to set your PC resolution to 1280 x 1024 @60Hz which is the native rsolution for this monitor. The Factory reset should be in the on screen menu setup.
User manual: http://www.retrevo.com/support/HannsG-HU171D-Monitors-manual/id/23256bh634/t/2/
Unless there is the problem inside the monitor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Computer monitor has blurry display
If you have another PC in the house, try plugging in your monitor to that PC instead, and see if the issue follow the monitor. If it does, you could do a Factory Reset on your monitor to see if the issue is fixed. You can do this by Hitting Menu button on your Monitor and finding the Factory reset Option. IF the issue is not fixed, you will most likely need a new monitor, you can easily find one online or at a local store for under 100 dollars.
Jul 03, 2012 | Dell Computers & Internet
I have a dell dimesion 3000 with a moniter that came with it from dell. a little while ago my nephew was messing with the moniter and made it really blurry. is there any way i can fix this?
There should be a menu button, and once in the menu, I believe there should be a Factory Reset Setting that you can choose and it should clear it up. If that does not work, the monitor could possibly be damaged and the blurry screen is the result. Good luck. Thanks. -Sa_Les_Ski
Feb 26, 2011 | Dell Dimension 3000 PC Desktop
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Blurry screen
check your cable VGA or DVI - reboot - if not work, uninstall your drivers and reinstall them
Sep 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Blurry images on camera
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Problems with Dell E176FP 17" LCD Monitor?
Kindly disconnect the monitor from the computer and power it on , if the screen is still blurry on the self test feature check , the monitor is bad.
You can press the menu button on the monitor and select Restore to Factory setting or Factory reset option. If the problem persists you can call LCD repair
http://www.lcdrepair.us/
Monday to Friday: 8:30 am to 4:30 pm
Central Standard Time
Phone :
469-521-7517
If you have purchased,the dell monitor seprately from the computer, it carries a three year replacement warranty.
Thanks
proton
Nov 21, 2008 | Dell E176FP 17" LCD Monitor
Dell UltraScan P1110 flat-screen monitor BLURRY?
The button you pressed is the reset button and according to the documentaton "returns the monitor to factory defaults".
Here's a link to the Dell support page for your monitor:
http://support.dell.com/support/edocs/monitors/p1110/En/index.htm
Regarding the lines that were orginally were trying to fix; see Damper Wires in Troubleshooting in the above documentation and you'll see that they're a fact of life with this type of monitor. I realize this may not have been your problem, but then again...
I'm surprised that the factory reset made things blurry. Usually this is the result of less than optimum settings on the display adapter in your computer rather than the monitor itself. The Trouble Shooting guide says the brightness and contrast being set too high can cause this so that may be worth checking.
I think you should check your display adapter settings after you try the Troubleshooting suggestions. On the desktop of your computer right click in an empty spot and select Properties. Click on the Settings tab and see what the resolution is. If it's not 1280x1024 you might want to try that. Everything on the screen may suddenly appear smaller so don't be surprised. I would also check the monitor frequency. This will probably be found under Advanced. Every display adapter is different so I can't tell you exactly where to look, just polk around. If you start changing things you may want to write down the original settings so you can at least get back to where you started if there's a problem.
Lastly, I want you to know I'm not paid to provide these suggestions. I know it's a strange hobby, but I like helping when I can. If you find this helpful I hope you'll take a moment and provide a positive rating. About half of the solutions I've posted have never been rated... Thanks and good luck.
Jan 02, 2008 | Computers & Internet
Microsoft HannsG HU171D 17" LCD Monitor Logo
388 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
