Question about Vizio VW37L 37 in. LCD HDTV
My tv has sound but no picture its completely black. i have disconnected and reconnected several times but to no success
Screen is black, tv turns on then off again.
If you wish to get some details; check the site linked here. Pull up older posts.
May 02, 2016 | Televison & Video
My lg tv picture wont come on
After turning the equipment on try pressing guide or menu to see if that makes picture come on. if not try disconnecting and reconnecting the cable going from cable box to T. V.
Nov 10, 2013 | Televison & Video
Sharp aquos 65- we have sound but no picture. What do I do?
There has been a power supply failure. The process of disconnecting then reconnecting the TV shocked the failing power supply back to life but ultimately it failed
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Fuzzy channels all of a sudden, cannot figure out how to get reception again?
Sounds like your cable has become disconnected at some point between the television and the outside connection. Start by unplugging the cable at the rear of the TV and then reconnect. Check the picture. If no success, then trace the wire back to the next connection point and disconnect and reconnect. Continue to trace your line until you get to the point where the outside cable connects to the house. If you do not get a clear picture, then you will need to purchase a new cable.
Jan 23, 2012 | Televison & Video
Hd tv got sound but no picture
Switch off the TV. Disconnect all the cables. Wait for some time. Reconnect all the cables and ensure they are not loose. Switch on the TV. It should work now with both picture and sound.
Jun 15, 2011 | LG 32LC51 32 in. HD-Ready LCD TV
Picture wnt out suddenly without any symptoms
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Apr 13, 2009 | Curtis CM32020S 32" TV
I have a pioneer elite plasma (Pro-1540HD),and my color settings are completely screwed up.(my kids and father-in-law were messing around with my remote.). I've gone through the manual and done everyhting...
Start with page 51 in the manual, disconnect all external sources(vcr,dvr,cable box,etc.) start the tv with just the cable from the wall jack straight to the tv. make adjustments as needed.when you have a satisfactory picture, reconnect the external sources one at a time and see if the picture changes after the addition of each component, if it does, the problem is probably that component. good luck.
Marc
Sep 13, 2008 | Pioneer Televison & Video
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Vizio VW37L 37 in. LCD HDTV Logo
130 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
