Question about Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck
What is the distributor rotation on a small block chevrolet
  • 21 Answers
Cloc wise as you're standing in front of the vehicle looking at the engine....(also engine front to back)...the cylinder bank on the left is numbers 2, 4, 6, 8 and the cylinder bank on the right is 1, 3, 5, 7....The spark plug wire order on the cap is 1, 8, 4, 3, 6, 5, 7, 2....Starting with number 1 spark plug wire on the cap being placed on the 2nd distributor post clockwise away from where the electrical socket is on the cap.
Posted on Aug 31, 2010
Where is number 1 on the distributor cap for 1989 gmc 305
distributor.pngfor all small block v8s, This would include 265, 283, 305, 327, 350, 400 cu. in. chevy small block v8 engines. Good Day! rotation clockwise.
Jul 14, 2014 | Cars & Trucks
What is the firing order of a small block chevy v8?
Rotation- clockwise, firing order- 18436572.
Nov 15, 2011 | Cars & Trucks
I need the diagram for plug wiring for 1992 ford tempo
Firing order is 1-3-4-2 Please rate if this helps
Installation of wires
  1. Whenever a high tension wire is removed for any reason from a spark plug, coil or distributor cap, or a new high tension wire is installed, Silicone Dielectric Compound WA-10, D7AZ-19A331-A (ESE-M1C171-A) or equivalent must be applied to boot before it is reconnected. Using a small clean tool, coat entire interior surface of boot with Silicone Dielectric Compound WA-10, D7AZ-19A331-A (ESE-M1C171-A) or equivalent.
  1. Insert each wire on proper terminal of distributor cap. Ensure wires are all the way down over their terminals. The No. 1 terminal is identified on cap. Install wires starting with No. 1 terminal.
  1. Remove wire retaining brackets from old high tension wire set and install them on new set in same relative position. Install wires in brackets on valve rocker arm covers.
  1. Connect wires to proper spark plugs.
  1. Install coil wire.
Installation of distributor
Before installing distributor, visually inspect distributor. Inspect O-ring. It should fit tightly and be free of cuts. The drive gear should be free of nicks, cracks and excessive wear. Rotate distributor drive shaft. It should move freely, without binding.
  1. To install distributor correctly, No. 1 piston must be at Top Dead Center (TDC) of compression stroke. Remove No. 1 cylinder spark plug and rotate engine clockwise until No. 1 piston is on the compression stroke.
  1. With No. 1 piston on compression stroke, align timing pointer with TDC on the crankshaft damper.
  1. Align locating boss on rotor with hole on armature. Fully seat rotor on distributor shaft.
  1. Rotate distributor shaft so blade on rotor is pointing toward mark on distributor base, that was previously made in Step 2 of the Removal procedure.
  1. While installing distributor, continue rotating rotor slightly so leading edge of the vane is centered in vane switch stator assembly.
  1. Rotate distributor in block to align leading edge of vane and vane switch stator assembly. Verify rotor is pointing at No. 1 mark on distributor base. If vane and vane switch stator cannot be aligned by rotating distributor in cylinder block, remove distributor enough to just disengage distributor gear from camshaft gear. Rotate rotor enough to engage distributor gear on another tooth of camshaft gear. Repeat Step 1 if necessary.
  1. Install distributor hold-down clamp and bolt. Tighten bolt, but leave it loose enough to rotate distributor.
  1. Install distributor cap, No. 1 spark plug and ignition wires. Check that ignition wires are securely connected to the cap and spark plugs. Tighten distributor cap hold-down screws to 2.0-2.6 Nm (18-23 lb-in).
  1. Reconnect distributor to wiring harness.
  1. Set initial timing according to procedures found in Section 13A of the Powertrain Control/Emissions Diagnosis Manual .
  1. After timing is set, tighten distributor hold-down bolts to 23-34 Nm (17-25 lb-ft).
  1. Recheck initial timing. Adjust if necessary.
Oct 11, 2011 | 1992 Ford Tempo
Hello, my 1989 chevy dually 3500 v8 wont start. Distributor was loose moving around
Gasoline I assume?? The timing is probably way off. Using the mark on the harmonic balancer and set to 0. Rotate the distributor so that the rotor is touching the #1 cylinder. Try to start vehicle, if starts, then use a timing light and set to spec by rotating distributor in very small increments. Tighten distributor. A service manual will help and they run ~$20 at any parts store.
Mar 29, 2010 | 1989 Chevrolet C/K 3500
Need to know how to install a new distributor and the firing order for a 4 cyl
Firing order is 1342. #1 cylinder is closest to front. (By pulleys)
See Figures 1, 2, 3 and 4
Engine Not Rotated
  1. Disconnect the negative battery terminal.
  2. Turn the engine over until No. 1 cylinder is at TDC of the compression stroke.
  3. Remove the distributor cap. Remove the wire harness connected to the side of the distributor.
  4. Mark the position of the distributor base in relation to the engine block with white paint or other suitable marking material, for reference when reinstalling the distributor.
  5. Loosen and remove the distributor hold-down bolt and clamp.
  6. Carefully begin lifting the distributor up and out. Once the shaft is clear of the engine compartment, inspect the shaft for cracks in the O-seal, the condition of the shaft drive gear and any other part which could lead to distributor problems in the future.
To install:
  1. Check to make sure the engine is still at TDC. Inspect distributor shaft hole to make sure it is free of dirt.
  2. Rotate distributor shaft until the painted mark on rotor is pointing toward painted mark on engine block made during removal.
  3. Continue rotating rotor slightly so leading edge of the vane is centered in vane the switch stator assembly.
  4. Dip entire distributor gear in engine assembly lubricant D9AZ-19579-D or equivalent.
If installing a new distributor, ALWAYS add engine assembly lubricant to the engine oil by pouring it through distributor hole onto the camshaft gear. Run engine at idle for at least five minutes before driving.
If vane and vane switch stator cannot be aligned by rotating distributor in cylinder block, remove distributor enough to just disengage distributor gear from camshaft gear. Rotate rotor enough to engage distributor gear on another tooth of the camshaft gear.
  1. Install the distributor retaining bolt and tighten so the distributor can just barely be moved.
  2. Install the distributor cap and, tighten screws to 18-23 inch lbs. (2.0-2.6 Nm).
  3. Reconnect battery cable. Start vehicle, and check timing. If timing needs adjustment, refer to the Ignition Timing section.
  4. After timing has been set, tighten distributor hold-down bolt to 17-2 ft. lbs. (23-34 Nm).
Engine Rotated with Distributor Removed
  1. If the crankshaft was rotated while the distributor was removed, the engine must be brought to TDC on the compression stroke of the No. 1 cylinder.
  2. Remove the No. 1 spark plug. Place a finger over the hole and rotate the crankshaft slowly in the direction of normal rotation until engine compression is felt.
  3. When engine compression is felt at the spark plug hole, indicating that the piston is approaching TDC, continue to turn the crankshaft until the timing mark on the pulley is aligned with the 0 mark on the engine front cover.
  4. Turn the distributor shaft until the ignition rotor is at the No. 1 firing position.
  5. Rotate distributor shaft so the blade on rotor is pointing toward paint mark on distributor base made during removal.
  6. Continue rotating rotor slightly so leading edge of the vane is centered in vane switch stator assembly. Verify rotor is pointing at No. 1 mark on distributor base.
  2. Install the rotor and distributor cap and connect all wiring. Tighten distributor cap to 18-23 inch lbs. (2.0-2.6 Nm).
Nov 17, 2009 | 1992 Mercury Topaz
Need fire order,spark plug wires replaced in incorrect place
For several engines....
Fig. 1: Buick-built 231, 252 V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
Fig. 2: Olds-built 260, 307, 350, 400, 403, 455 Pontiac-built 265, 301, 350, 400, 455 V8 Engine Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Counter-clockwise
Fig. 3: Buick-built 350 V8 Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Fig. 4: Chevrolet-built 267, 305, 350 Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: clockwise
Fig. 5: Chevrolet-built 262 Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
Hope helped with this (remember rated this help) Good luck.
Nov 05, 2009 | 1985 Oldsmobile Delta 88
Spark plug order to distributor
For a 1985 Chevy S10 with a 2.8L engine the firing order is: 1-2-3-4-5-6 The Distributor rotation is clockwise.Take off the cap and bump engine till the rotor points to the no. 1 plug. this is the no.1 contact on the cap. follow rotation around the cap in order. {ie. 2,3,4 ect.} hope this helps.
Oct 12, 2009 | 1985 Chevrolet Chevy
Could you show a spark plug wire diagram 1984 cadillac eldorado?
Firing order 12,734,568. Cylinder 1 is the front left wing seeing the engine cylinder 2 is right wing. DERCHO van left the odd couple. 1357 Left 2468 Right
Aug 30, 2009 | 1984 Cadillac Eldorado
Distributor
The distributor is on the back of the engine (that's the side that the transmission hooks up to). You will need a socket set and a paint marker (you might need a screw driver too). Remove the distributor cap (if the distributor cap is good you can leave the plug wires attached) carefully mark the rotor and the distributor so that you can easily see exactly how the two aligned while attached to the engine. trace an outline around the base of the distributor where it fits into the block so that when you remove the distributor you will be able to clearly see exactly how it sat on the engine. remove the bolts that secure the distributor to the engine. Give the distributor a light twist and pull hard directly away from the engine. Realign the rotor and distributor as they were aligned previously. Make note of relative position of the splines/forks on the back side of the distributor that fit into the engine. align your replacement distributor and rotor so that it matches the old one exactly. mark the correct alignment. Making sure that it is still aligned. insert the new distributor into the engine and lightly hand tighten the screws. Make sure that the screws are just tight enough to hold the distributor in place but loose enough to rotate it with ease. Make sure that the rotor is still properly aligned. make sure that the distributor is sitting against the engine block exactly how the old one was. Double check the rotor alignment and tighten the screws so that the distributor is snug but so that you can still rotate the distributor with some effort. double check the rotor alignment and put the cap back on. start the engine and give it some gas by manipulating the throttle body at the engine compartment. If the engine doesn't sound right, slowly and carefully rotate the distributor until it engine sounds like it should and tighten the bolts so that it can't be rotated any more. close the hood and go for a drive. you can adjust the timing by rotating the distributor if it still doesn't seem quite right. 0 Pts Rate Answer
Jun 14, 2008 | 1996 Chevrolet Caprice
Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck Logo
354 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
