Can my acoustic solutions lcd32761hdf connect to a laptop? It has a pc button on the remote control, but it does not have a vga port on back of tv
  • Anonymous Mar 13, 2014
    I have an Acoustic Solutions LCD32761HDF tv. I want to connect my laptop to this to watch tv. The laptop is a sony Vaio VGN-NS10L. What do I need?
  • 110 Answers
Check the connections. If you have a DVI input or a HDMI input you can connect your laptop. You can also check the connect panel section of the manual to locate the proper input for the computer. You will need to get the right cable to connect the laptop vga to the HDMI or DVI input.
Posted on May 15, 2010
Testimonial: "cheers ma dears"
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
How do i connect my nexus 7 2nd generation to my acoustic solutions tv model LCD32761HDF, I want to watch filmon on a large screen?
Hi, Your Nexus has RCA connections on the back and so does the TV. You only need the audio connections to work. Another way to go is HDMI cable. Your TV may already have them. Good luck.
May 01, 2014 | LG Televison & Video
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
I cannot connect to my hp dv5220us to the tv through vga. i think the vga driver is not installed . please suggest me which driver am i supposed o download.thank you.
Most laptops have three modes for video:
* output only to internal LCD screen
* output only to external VGA port
* output to both internal and external
Hold down the 'fn' ("function") key on the keyboard, and press one of the twelve 'F' ("function") keys, to "toggle" the video through the above 3 modes of operation, until you get output through the VGA port to the TV.
Also, on the TV, use the "input" or "source" button on the TV's remote control to select the 'VGA' input-port as the signal to be displayed on the TV screen.
Jul 16, 2011 | HP Pavilion Dv5220us Notebook
I have a inspiron1300,and i wondered if it is possibe to connect it to my philips hdready tv.am sure which cable to use
You never mentioned what model Philips TV you have, however I've researched several and most seem to have a VGA video port in the back of them. If you have one of these (15 pin D connector) on the back of your TV you should be able to purchase a corresponding VGA cable (you'll want female pins on one side of the cable and male pins on the other side) and plug one side into the VGA port on your laptop and the other cable into the TV. Then use your TV remote to select that input. Should work fine!
See item 8 in the attached user guide link to see what I'm talking about. http://download.p4c.philips.com/files/4/42pfl3403_98/42pfl3403_98_qsg_eng.pdf
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 23, 2011 | Computers & Internet
I have a Laptop and an Acoustic Solutions Tv. But what i want to know is how to connect my laptop to the tv? What cables do i need? My laptop has the vga connection but the back of my tv will. i...
I believe the number that you have sent me is the serial number, Your TV should have a name and model #. For example (Sony Bravia model #00000) Yours would be RCA ? #?. The model number should be on the back of the TV. Is the TV an LCD flat screen? If it is and is fairly new it will have a special place to plug a PC into it. With the model name and number of your TV I can look for the manual and lok at the connection set up for your model.
Dec 28, 2010 | Televison & Video
How do i access hdmi 2 on my lcd32761hdf tv. i have cable (virgin) in hdmi1, dvd in ext 1 & the wii in ext 2. i now have a ps3 i would like to set up.
You can't access it simply because it doesn't exist - your tv has only one HDMI jack.
Your only option is to use a HDMI switch, one like
http://www.amazon.com/HM-501-5-PORT-HDMI-control-cable/dp/B000FHQMFK
Jun 05, 2010 | Acoustic Solutions M 100 Main / Stereo...
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
Manual for acoustic solutions lcd32805hd tv
You will need an HDMi lead running from the port on the back of your television to the port on a compatible DVD player/recorder, then toggle (keep pressing) the AV/Source button on the remote to switch the television mode to HDMi.
The HDMi port will be marked HDMi on the back of your television.
Jan 01, 2009 | Televison & Video
Televison & Video Logo
600 people viewed this question
Top Televison & Video Experts
Electro Med Services...
