Question about Microsoft Windows Vista Ultimate Edition
Graphics devlopment hello... can any one help me how to run graphics program in tc? vista does not support full screen mode for dos where as before running any graphics program we must have full screen dos shell...
  • 655 Answers
Sorry vishu Micro Soft Vista is not going to support full screen DOS mode in any mean.
Thanks
Iqbal
Posted on Mar 30, 2008
SOURCE:
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
Graphics in c not working in my pc
Uninstall Turbo C++
Restart your computer
Reinstall Turbo C++
Try your program, again.
Jul 30, 2010 | ASUS M2N-MX Motherboard
Turbo c is not working in full screen in windows 7. Please let me know if you know the Soluation.
Vista and upwards do not support full screen for DOS applications. If you need to use it in full screen mode, use DOS BOX. But it will crash if you perform pointer or memory based operations.
Oct 02, 2009 | Dell Inspiron 1501 Notebook
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
Full screen TC
Hi Yes , You can run C++ in full mode. Plz follow the below step.
Hold Alt Key and hit Enter key it will move in full mode.
If you want permanent full mode option then right click and select proprties. In display select full screen and that it.
Feb 04, 2009 | Microsoft Windows Vista Ultimate Edition
Turbo-c++ is not installed in full screen
Hi sagar,
Turbo C++ 3.0 is made for MS DOS 6.22 environment. In windows also we can run Turbo C because windows environment provides all native services of DOS. But in Windows VISTA some of the services are revoked. So to enable them either Vista is to be reconfigured or some add-ins are to me installed.
Other versions those can work in Vista are BOROLAND C++ 4.5, VISUAL C++ 6.0, and Visual Studio 2008. But in all these the graphics header file <graphics.h> will not work. Try to find an appropriate graphics header file or copy graphics.h in the cource directory and use #include "graphics.h" command in your C Program.
Please revert to me if having problems.
Zulfikar Ali
[email protected]
09899780221
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
ABOUT TURBO C++
Vista doesn't support full screen mode while operating Turbo C++,
and its also doesn't support graphics(bgi) while operating it.
There are lots of compatibility problems with Vista --
I have Vista Home Premium and have warning when I start VC++ 2005 Express!
I just tried running tc.exe and did not get the warning message you reported.
Although it would only run in the small window.
Your best bet is to download either VC++ 2005 Express or Dev-C++.
They both run full-screen.
Sep 10, 2008 | Computers & Internet
Turbo c doesnt have a full screen version on vista..
FOLLOWS THESE STEPS TO SOLVE THIS PROBLEM...
  1. Copy the “DOSBox0.72-win32-installer.exe” from http://www.download3k.com/Install-DOSBox.html
  1. Install it with default settings.
  2. Create a folder “Turboc” in your C:\> directory.
  3. Copy your turbo c folder such as “TC” in the folder “Turboc”. This is shown in the following diagram.
fifth.jpg?w=625&h=526<!Run the software you installed. Its icon is present on the your desktop.
  1. This will run the software, as shown in the fig:
first.jpg?w=573&h=507<!
Write these lines in the screen:
mount c c:\>Turboc
Press Enter
Following message will appear on the screen
Drive c is mounted as local directory c:\Turboc\
Now write:
C:
Press Enter
Now write:
cd TC
Press Enter,
Now write
cd bin
Press Enter,
Now write
Tc.exe
All these steps are shown in the following figure:
8.
Now following screen will appear:
10. Press Alt + Enter. Full screen mode of Turbo C will appear.
[updated]IMPORTANT : Don’t use shortcut Ctrl+F9 bcoz it is a shortcut for dos box to exit
Happy Coding
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
How to run turbo C editor in full screen in windows vista
HERE is the simple trick :To use Turbo C++ IDE in windows 7 or in Vista; For those who wants to learn C/C++ just uninstall your "Graphics driver "
For that Computers->properties->device manager->Display Adapters->graphics driver version u have uninstall that...And after log off Run your "C:\\TC\\BIN\\TC.exe".it will open in full screen...
for more visit www.hackersorigin.com
or
forum.hackersorigin.com
Mar 22, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
