Question about Pelonis KCD-25YI Air Conditioner
How do i stop the waterfull from blanking
The waterfull is blanking but there is no water.so what do i do
  • 53 Answers
There is no water because its trapped inside , open system an locate the pan an clean out the bottom make sure the hose is clear if you dont have any solution for the unit then pour a cap full of bleach in the system,that should take care of your problem
Posted on May 16, 2010
Dishwasher was working fine then it just stopped and led screen went blank water didn't drain out and now it wont go checked handle and contact there both ok stopped just after starting cheers.
This is an indication that the power supply has failed. It may be a bad fuse or it could be a latch switch. If it is full of water, you can use a wet vacuum cleaner to drain it.
Jan 28, 2017 | Dishwashers
Controller is blank but we still have hot water so why no display?
The system control is running in the background and as long as it's working the screen is not not doing anything. You can use it until you want to change settings or until the system stops working. If you want to spend the money you can but you don't really need to. Good luck with your choice.
Mar 14, 2016 | Water Water Heaters
What causes water to build up in driver's foot-well of 1996 Honda CRV?
could be the heater radiator that is leaking.they are normaly behind the dash board where the fan blows over it to supply heat.
If you can locate heater pipes in engine bay, blank them of and see if water build up stops. these radiators are rather tricky to get to!
Aug 17, 2013 | Honda CRV Cars & Trucks
14 month old water heater stopped working
Which water heater do you have??? What is year of manufacture?
Rheem-GE Geo spring hybrid: Rheem-GE heat pump ?? then call GE 888-443-4394 for recommendation of local service technician and expect to pay $400 and do not expect problem to get solved unless area has experienced, certified water-heater-air-conditioning expert.
Installation must be done correctly. For example if water heater is set too close to wall, then service technician will expect you to hire plumber to empty tank and move away from wall and install correctly before repair can resume. It's a nuisance, but this is accurate information based on others who have posted questions.
Copy following link for resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
There are no service manuals available for homeowner, which is why this product is unwise choice for any installation.
Unit is not protected from power surge. Install one-time-use whole house power surge.
Make sure unit is connected to 240V, and that breaker is not tripped off on one leg. Move wires to another same size breaker. Check wire connections at water heater and confirm 240V.
Check that installation is done correctly as shown on link above.
14 months old means that labor warranty has expired by 2 months. However parts are still covered.
Do not buy expensive water heaters that cannot be repaired easily by homeowner. This single repair can eliminate all anticipated savings from buying product.
If expected heat-pump repair will cost $400, then buy off-the-shelf electric water heater from Lowes for $250 and save the expensive repair.
Gene
Jul 25, 2013 | GeoSpring Hybrid Water Heater
What is wrong with my Amcor KF9000E Portable Air Conditioner?
Do not post the asked for info as a new problem, use the link sent you to answer at the original post.
Jun 01, 2012 | Heating & Cooling
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
Razr v3 blanked out randomly
if the back light for my lazor stopped working ramdomly means the cell was fall in the water and that cell mother board is gone thats why the problem will came ."THE CELL MOTHER BOARD IS GONE" thats why the back light for my razor stopped working ramdomly.ok bai sir
Feb 08, 2009 | Motorola Mobility RAZR V3
LG8300 stuck vibrating continuously, now main screen blank
Sounds like water damage. Are there any red stickers under the battery? If so, then it is water damaged.
Either way, if you are the primary line then Verizon may offer you an early upgrade if your rateplan is above a certain price point (if that's who your on). If not, you can do an insurance claim, if you don't have insurance then you will have to either pay full price for a new one, or purchased a used one.
Hope this helps,
Simon.
Nov 17, 2008 | LG VX8300 Cellular Phone
Pelonis KCD-25YI Air Conditioner Logo
129 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
