Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
ICEMAKER AUTOMATICALLY GOES INTO CLEANING MODE MELTING THE ICE
  • commish26 May 15, 2010
    KITCHENAID ICEMAKER STAND ALONE. HAS THREE BUTTON AND A LIGHT INSIDE. OFF ON CLEAN AND CLEAN LIGHT. AFTER TURNING MACHINE ON IT GOES INTO CLEANING MODE BY ITSELF IN ABOUT TWO HOURS
    KITCHENAID STAND ALONE ICEMKER GOES INTO CLEANING MODE, THEN JUST HAS CLEANING LIGHT FLASHING AND NOT MAKING ICE. VERY HOT IN CHAMBER
    President:
  • 1,561 Answers
Test the themistor if the LED light (located on the right-hand side of the icemaker) starts flashing on and off. This means that the icemaker is in the Fault mode. Locate the thermistor in the icemaker's circuit board (See your user manual for the exact location in your particular icemaker.) Pull it out and connect the thermistor's terminals to the leads of a volt/ohm meter. If your thermistor tests bad, you'll need to purchase a new one. If the thermistor tests good but the icemaker still does not work correctly, and the unit is still in Fault mode, you will most likely need to purchase a new icemaker.
Check to see if the auger screw is broken if your icemaker is not working correctly. You will need to take apart the icemaker to locate the auger bucket. These mechanisms break when the freezer gets too warm and enough ice at the bottom of the auger bucket melts. When the freezer gets cold again, the water refreezes around the screw. If you try to use the icemaker, the auger motor turns the screw, now frozen in ice, and breaks it.
Check to make sure the power cord is plugged into an outlet if the icemaker does not operate. If this is not the problem, make sure the control switch is not set to "Off." The control switch is located at the top center of the icemaker. You may also have a blown fuse or a tripped circuit breaker. If that is the case, replace the fuse or reset the breaker. The drain line may also be kinked; if it is, straighten it out.Make sure the water supply is turned on or connected if the icemaker turns on but does not produce ice. Check to see if lint is blocking the airflow through the condenser. The condenser is located behind the lower access panel on the front of the icemaker. If this is the case, clean the condenser coils with the brush attachment of a vacuum cleaner. If a white scale has built up in the icemaker's water or freezing system, clean the icemaker. The room temperature may also be colder than normal. If the room temperature is below 55 degrees F, the bin thermostat may sense the cold room and shut off, even if the bin is not full of ice.Shut off the icemaker for at least one hour if it pumps continuously but produces no ice. There is an ice sheet trapped on the cutter grid, and it needs time to melt. After an hour, turn the icemaker back on. The icemaker will restart itself and flush water through the system to begin a new cycle.
Take care.
Posted on May 15, 2010
  • KitchenAid Master
  • 12,061 Answers
Http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=43
Above is your service manual, this is used to troubleshoot and hopefully repair, your unit.
http://www.diychatroom.com/f47/kitchenaid-ice-maker-not-working-6197/
http://www.applianceblog.com/mainforums/kitchenaid/3003-ice-maker-help-kitchenaid-ksrb25fk-side-side.html
Ok above are some Forum links, where your problem is discussed and fixes are also given. Between your service manual and these sites i feel sure you will be able to isolate and hopefully remedy your problem.
    THANKX FOR THE LINKS, CANT SEEM TO FIND ASSOCIATED PROBLEM.
    MY IEMAKER IS STAND ALONE, AND AUTOMATICALLY GOES INTO CLEANING MODE NO MATTER WHAT I DO... CAN U HELP??
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    THIS IS A STAND ALONE ICEMAKER 18 INCH WIDE
My Icemaker won't keep the ice once it makes it
What make and model of ice maker do you have?
Is the unit making ice? If so, about how much?
Most commercial bin type ice makers are not engineered to maintain the ice once it drops into the bin. Older ice is intended to melt and the water should drain out of the bin as new ice is deposited on top.
It may be that you are consuming ice at a rate greater than the unit is designed to produce ice, or that the unit is not set to the highest ice production rate (if adjustable).
Alternatively, if the inside of the bin is hot (warm) you may have another problem with the unit (e.g., gasket leak). Was the unit previously working? If so, are you aware of any events that took place just prior to the change?
Some units have a defrost or a cleaning mode, which will actually generate heat inside the unit. Make sure the unit is set to the correct mode.
Feb 12, 2014 | Manitowoc QM30 Under Counter Ice Maker
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
Icemaker is warm and stopped making ice
The ice maker has a heater that comes on just before the ice dumps to assist in releasing the cubes. Sounds to me that you need to unplug the ice maker and begin a search for a new replacement ice maker=> 67004-S Ice Maker Assembly
You may want to call them to see if the ice maker is rebuildable because the price for the ice maker is really high. If you have questions I will be here to answer them for you, Thanks Sea Breeze
Jul 12, 2012 | Refrigerators
I noticed the freezer was not working as well as usual. The back wall of the freezer, by the ice maker (not hooked up) is very hot. What's going on?
The heater on the icemaker is staying on. Be very careful not to touch the bottom of the icemaker and remove it from freezer asap. Do not touch the bottom of the icemaker mold because thios will severly burn you. Take the icemaker out or the freezer wall will start melting.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
Melting ice in icemaker. Repairman out twice and says he fixed it and yet my ice continues to melt and drips inside the freezer.
One of my most disliked things in life is to have a repairman go into the home and make repeat visits. Then when they have the gall to say it is fixed and they are back for a 3rd time.... (need I say more!?!!
Melting ice in the icemaker only means that the mold heater element for initially loosening the ice cubes from the tray in the icemaker is not shutting off or the bi-metal thermostat in the icemaker is bad.
The ice maker test procedures are here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
I would print that out and hand it to the repairman the next time he walks through the door. Simply state "This may help you compete the job right." and leave it at that.
The sad news it it could take replacement of the ice maker to rid yourself of the melting ice saga.
Hopefully he can use the printout and then get the necessary parts to get you back in business real soon.
Thanks for using Fixya!
Feb 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer ice making compartment stays in lock mode
the thermostat in the ice machine is not working. its most likely tha the icemaker is a FSP whirlpool it's a lot surer to just replace the hole head and be done with it unless you'd like keep dealing with it.
Mar 18, 2009 | Freezers
Subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Oct 18, 2008 | Refrigerators
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
481 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
