Question about Sony KV-32S45 32" TV
I can't get any power? What is wrong? I tried with the remote and also using the buttons on the tv...still no power.
  • 979 Answers
Hello cwcritters, hi, does your tv front panel has any pilot light on or nay sign that the TV is on, if yes, there is problem with the main board and power supply, probably a short, this TV is on standby, here are the things to check, a shorted horizontal output transistor, a bad voltage regulator, or any ICs that are overheating, NOW if there is no light at all, then your TV may have fuse open. A fuse opens when a user plugs the TV while the power switch is on, causing a surge of electric current. or TV develops a shorted regulator. If you dont know anything about electronics, dont do the service yourself, you may further damage the TV, better call service.
Posted on May 15, 2010
Testimonial: "Though I don't know much about eletronics it gives me an Idea of what is wrong for when I take it in for repairs. Great help! Fast reply! I will highly recomend you! "
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
Dec 15, 2015 | Philips HTL2101A/F7 40 Watts Sound Bar
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
How do I turn on the tv without the remote
There are manual control buttons like Power,Menu,Channel up/down,Volume up/down on the right side tv bazel frame tv facing u.If the tv working correctly nothing wrong with it.That all the tv manual control buttons for the tv.Or try website like Remotes.com to buy the tv original remote or a very close compatible one to use.
Aug 26, 2011 | Memorex MLT1912 19 in. LCD TV
My HDTV, 42", won't turn off, change
Check the tv manual control buttons right side of the tv bazel frame tv facing u,see if u can used the buttons like power, chanels - + or volumes - + from it.If u can, mean the tv have problems with is remote control.Change new batteries for the remote,still no response from the remote.Mean the remote is dead.Try website like Remotes.com to buy an exact remote or very close it.
Jan 17, 2011 | Sylvania LC420SS8 LCD TV
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Sony KV-32S45 32" TV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
