Question about Sport & Outdoor - Others
98 polaris sportsman won't rev up, got a used carb but same thing. startsup and runs, but when i push on the gas it wont revup, it trys to rev but it wont
  • 4 more comments
  • Matthew Albert
    Matthew Albert May 15, 2010
    ty for trying m42153, but that link dont help me at all,
    More info.....
    Atv sat for 7 years, did the samething back then, got a used carb thinking that would fix but NO,,
    startup fine runs good, just won't rev up,
  • Matthew Albert
    May 15, 2010 - i tryed the yellow button, i was thinking the samething,, but it did not work,, also the used carb from ebay came with is own throttle control so i used it,,
    7 years ago we wre pulling some logs when it started, lost power, its like its not geting enough gas,
    i took the air box off and you can here boging/air sucking noise, when you let go of the throttle is stops makeing that noise,, it Idols and starts fine
  • Matthew Albert
    ty for trying but i tryed a new filter, and blow the lines out 7 years ago when it started,
    its been 7 years ill recheck but i dont think thats the problum,
    back then i tryed many things, Came down to it must be the carb, havint worked on it for 7 years..so i got a used carb,, this new/used carb will leak gas from the bottom, i think the flot is stuck, only leaks when its off, i have to shut the gas off when im done working on it,
    the problum is the same with both carbs, SOO i dont think its a carb problum, I was hoping it was i payed 250 for the new.used leaky carb which is BS that i have to open a carb i payed so much for.
    When i get it running right ill worry about fixing the over flow.
    remember the first carb did not leek and i cleand it thinking i loss power from that..
    I get the same exact problum i had with the old carb 7 years ago.
  • Matthew Albert
    ty for trying but it idols just fine, like i said the problum remained the same with both carbs,
    Are you saying both carbs need to be adjusted?
    it starts and idols fine i dont think adjusting that will help, its already idols fine, TY for trying but can you see everything it posted to other techs here? if so plz take the time to read everything, the first tech already tryed a quick $ with his wast of time link he gave me,
    I got all weekend off to work on this I will retry the gas lines and filer, but im looking for someone that works on polaris atv's,
    i read that a worn cam lobe will do this over time but this started and got bad fast..
    like i said was pulling logs started to loss power, i got it back to the house [10min] and that was it no power won't rev up, so back then I did some carb work then gaveup,, that was 7 years ago and it sat in that spot outside for all this time..
    put the new carb in and started up fine after all this time, but the problum remained.
  • Matthew Albert
    I know what yor trying to say [do the work!!]AND YOUR RIGHT!
    i was hoping to find someone that had the same problum, I got all weekend,
    Ill check the cam first, i need to get that off my mind,
    when i started to work on it after 7 years i wanted to make sure its not fobar,, it runs so i want to fix, The links wont help for this but they are good links to haave ty
  • Matthew Albert
    Matthew Albert May 16, 2010
    It was the cam lobe
  • Sport & Outd... Master
  • 12,061 Answers
Http://www.smallengineadvisor.com/memberdetails.htm
A great DIY motor troubleshooting
http://videos.wittysparks.com/id/3648715610
Above is a service and repair manual, in Video format.
http://www.scribd.com/doc/19783206/1998-Polaris-Sportsman-500A-Parts-Manual
Above is the parts manual, below is a service manual in PDF format. I am sure with all this you will be able to troubleshoot and repair your motor.
Some tips, Check, Battery, Check EARTH, Check, Spark plug lead, (Replace on spec usual) Spark plug (Again replace on spec) Check any "Points" system, be they mechanical, or electronic, Check the capacitor, if there is one. Now, make sure you are getting a good hot spark. Now when you are sure you have a good electrical side, we troubleshoot the "Gas" side of things, now, check, the Carburettor, check, the Float, and Float Bowl, check the Float Valve as well, check Choke is OK, check, Butterfly Valve is OK, Set the Mixture, make sure you have good fuel flow to carburettor. Hopefully between this advice and the links provided you should be able to remedy your problem. http://www.freepdfmanual.com/2009/02/06/polaris-sportsman-400-atv-parts-catalog-2005
Posted on May 15, 2010
Your jetting is off, find the pilot jet on the carburetor. If it is a Mikuni carburetor then it's an air pilot. Move the pilot jet out 1/4 turn at a time, this should increase the amount of air mixing with fuel at idol
    President:
  • 1,768 Answers
You may have a clogged in line fuel filter.
check your fuel line also for crimping.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The problem is in the throttle control try holding the override button on the left hand grip and rev it up if it revs then the thstuck throttle control is bad it in the right hand grip under the cover with the two screws had this problem on a 1996 polaris it also keeps you from reving it in reverse unless you hold down the overide button.
  • Matthew Albert
    Genius:
  • 1,354 Answers
Hi
go to folowing link your ger all solution for Polaris
http://www.pdfgeni.com/book/polaris-sportsman-500-warn-winch-install-pdf.html
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Jan 15, 2017 | GAS Motorcycles
Sportsman 90 idles wont rev
Replace spark plug (gap correctly),Drain all fuel, replace fuel filter, replenish tank with fresh fuel, do a thorough readjustment of the carb settings (last resort - remove and rebuild carb)
Feb 17, 2015 | Polaris 2008 Sportsman 90
My 700 sportsman starts but won't running
sounds like the carb is gummed up try with it running to spray choke cleaner in the system this may clean out the system if not a carb rebuild will be needed
Sep 03, 2012 | Polaris Garden
97 polaris 500 sportsman 4x4 atv carburetor adjustments,wont rev and very rich i removed carb, cleaned jets and installed new needle seat
If you have gone through the carburetor and your atv still won't rev it sounds like the exhaust lobe on the camshaft is going flat. They have an overhead camshaft in the 500 motor and the exhaust lobes seem to wear down if the oil is broken down (gas in oil) or if the wrong oil is used. Easy way to tell is to remove the 8 screws on valve cover and the spark plug. Then remove the 4 screws holding down the rocker arms. Once the rocker arms are removed you can see the camshaft, pull on the recoil rope to rotate engine until the lobes are facing upward. The two outer lobes are the intake lobes, and the center is the exhaust lobe. If the exhaust is worn, you will definitely be able to tell because it should be about the same height as the intake. Or if you don't feel comfortable doing that I would recommend a reputable repair shop. Hope this helps, and if you need more help let me know, Daniel.
Sep 28, 2011 | Polaris ATV
I have an 04 or 05 Polaris Sportsman 700 twin 4X4 that just started to have problems. I was gone for 2 months and when I got back it won't start unless the choke is full out and will only run that way. It...
I had this problem on a 05 polaris sportsman 700 carb... I dissasembled the carb. cleaned it all out... It actually was fine. It turned out the torque of the motor broke the hard rubber intake that connects the airbox to the motor... This part is $60 and takes 2 bolts to change! mjninke@yahoo.com
Oct 09, 2009 | Polaris ATV
I have a 97 sportsman 500 . it starts right up and runs until you give it all the throttel then it bogs down like its not getting enough gas.
Bad gas..clogged jets in carb...very dirty air filter....clogged gas line or gas tank....stuck float in carb.
Oct 07, 2009 | Polaris ATV
Bogs down & spits back through carb.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
Sep 19, 2009 | Polaris ATV
2004 POLARIS SPORTSMAN 700. THERE IS GAS IN THE
you posibly have bad ring or broken ring or piston issue
Aug 24, 2009 | Polaris ATV
Sport & Outdoor - Others Logo
1,003 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
