Question about Kenmore Elite 45986 Front Load Washer
In the elite kenmore smartwash quietpack 9 HE 4t - what does error code HF mean?
  • Kenmore Master
  • 1,205 Answers
If you still know where the brochure is I would look in the chapter "troubleshooting"
If the brochure is not where it should be, I would "google" the brand name and the no of the appliance More likly than not you will find the answer there. This method has helped me very often.
Posted on May 15, 2010
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
I have had a kenmore elite smartwash for 2 years -- I do not have it stacked. I just started a load and after 10 seconds or so, I received the F20 error code. what should I do?
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Nov 21, 2009 | Kenmore Elite 45986 Front Load Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F20
take the kick panel off inside you will find the tech sheet it will give you a list of error codes. i believe you have a bad pressure switch or it could be something stuck in your pump. untwist and check the pump filter. let me know how it goes
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash/he4t (error code)
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
489 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
