Back to:
Tags:
Teac A-H300 Amplifier
Teac A-H300 Amplifier (by 2 users)
posted by sjp23480 on Mar 30, 2008
A recent problem has occurred whereby when I switch on my system(amp, CD, TAPE DECK, DAB tuner and analogue tuner) as soon as the amp has warmed up (3-4 seconds) within 1/2 a second of sound coming from the speakers, the amp cuts out.
The amp itself locks up - unable to change inputs, etc and the light around the standby button flashes. All the other components remain active and fully operational (as far as I can make out). All I can do is switch the system off via the remote or the standby button on the amp.
I've disconnected the power and reset the amp using the master power switch - but to no avail!
Referred to the manual - but no help - anyone know what might be going on????
Thanks,
Steve
Comment by sjp23480, posted on Apr 01, 2008
Thanks Duncan - actually found the problem _ the aerial had been pulled from the wall socket (pesky kids) and was resting on the plugs on the speaker leads and shorting them out>
reconnected the aerial cable and bingo! everything works!
Thanks again,
Steve
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by scottie37, posted on Sep 15, 2008
My amp does exactly the same, except I don't know where the power surge is coming from. I can't see anything obvious that is affecting the plugs or cables at the back. Any suggestions?
Where is the master reset button?
Thanks, Scott.
Best Solution
posted on Mar 31, 2008
Helpful (85)
Duncan
Rank:Guru Guru
Rating: 85%, 176 votes
It may be your unit is going into protect mode because of a problem in the power amp stage of your amp. If so, then it is time to see a repair shop. Good luck.
Rating Locked! (?) sjp23480 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Teac A-H300 Amplifier:
I don't want to Accept this solution
Can you Help with these Amplifiers and Preamps problems?
my behringer europower pmh660m power amp wont power up...
Am using ps3 with hdmi to TV, TV has no audio out from...
Tengo un equipo de audio marca Philips compuesto de...
Left and right speakers work - centre and surround do...
i guess i did it now !!i think shes a gonner !!! i heard...
Loading problems.
Repair Service
Find Amplifier and Pre. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
