Question about Kenmore 63942 Dryer
For some reason we are getting water dripping from the right front portion of the dryer. what could be causing this?
  • 401 Answers
SOUNDS LIKE YOUR HOUSE VENT IS PLUGGED.CHECK THE OUTSIDE FLAPPER TO MAKE SURE ITS CLEAR. OTHER THEN THAT YOU SHOULD HAVE IT CLEANED
Posted on May 15, 2010
I have a Kenmore he5 steam dryer that is dripping water out of the steam nozzle on the inside of the drum. This happens on any drying cycle and causes clothes to not dry. How do I fix this?
Does it drip just when the unit is operating or do you find water in the machine when it is not running? Try shutting the water off to the dryer and see if the dripping stops. If it does the water inlet valve needs to be replaced.
Feb 12, 2016 | Kenmore Dryers
Water dripping from front bottum of freezer compartment -inside of frigerator
The reason for that water drip is from a blocked drain of the defrost,since that drain is blocked it is causing water to collect/drip from the freezer.I have written a tip about how to clear that drain,
http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Oct 27, 2011 | Refrigerators
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
After each cicle of washing its coming on the floor some water like 50 ml
Whirlpool AWM6120
There are several items which may contribute to your issue at hand.
A plastic gasket seals the front to back portion right above the location where deprey gets caught when in wash cycle. When this builds up with trash and gunk not caught by the filter, it will cause water to leak out and eventually onto the floor. You may also have a build up in the drainage hose backup and release for dirty water. Check this area thoroughly!! You can also see exactly where the water is dripping so that we can identify what is the root cause of the water leak. Nothing sounds major so replacing the unit is not a good idea and would be expensive.
Jan 12, 2011 | Whirlpool AWM6120 Front Load Washer
Water is backing up and dripping out of wall unit. I've checked drainage pipe and its clear. water is not getting into drainage pipe in unit.
The water dripping from evapourator is due to clogging of the cooling pins.where in the condensed water logs into the front portion into the filter,the front pannel and to the wall.If the unit is slightly tilted, this would be reduced.use a good brush and air pressure to clean the fins.If periodical cleaning of the filter is not done,this can happen.
Sep 02, 2010 | Heating & Cooling
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have model #TR185-L water dripping and freezing food
the freon pipes have a leak go to a appliance store and get new ones
Jul 28, 2009 | Refrigerators
Leak
bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front panel..now your in ,,to put back reverse...att'' always unplug unit first
Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 63942 Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
