Question about Sunbeam 4039 Iron
My steam iron is leaking brown liquid.
Model number on the bottom plate is 4057M301A13
Seems like it just needs a good cleaning on the inside. There are a few drops of dirty water that come out when I first start to iron. Bad enough that I have to re-wash the shirt.
How do I get that gunk (pardon my non-technical talk) out of the water chamber?
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
ZJLimited
  • 17970 Answers
SOURCE: Iron was leaking rusty water.
There will be a build up inside the hotplate where the water is vapourised. To clear this, refer to your manual or simply put on high steam setting, rest on it's heel, and wait for the indicator light to go out, then unplug, and hold horizontal over the sink. Press any steam boost buttons you have untill the iron is cold - and you just get water flowing out.
1.- Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2.- Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3.- Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4.- Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
Keep us updated.
Posted on Jun 30, 2011
raevenzero
  • 53 Answers
SOURCE: irons will not heat properly
This may sound weird, but try them at someone else's house, it could be possible that your wiring is not allowing them the amperage they need to heat properly.
Posted on Nov 27, 2007
  • 2039 Answers
SOURCE: removing limescale from iron and steam chamber.
1part descaler 1 part water shake it and rinse very good
Posted on Jan 27, 2008
protek480
  • 1714 Answers
SOURCE: brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Posted on Jul 02, 2009
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
Tip
Cleaning a Steam Iron White Scale and Brown Water
If you are having problems with your steam iron spitting out brown water or white scale all over your clothing, then you need to read this tip.
Both of these problems are caused by poor quality water being used in your steam iron.
The problems are different in that they are caused by two different types of poor water quality. The brown coloring of the water is usually caused by organic matter or iron mineral in your tap water.
If you are getting white scale on your clothing from your iron then it is usually because of calcium or other minerals in your tap water.
Either of these problems can also contribute to spitting or leaking of the iron when in use.
To clean the inside of the iron you must first empty all the water from the iron. Then fill the iron half full with bottled spring water and then fill to full with vinegar. Run the iron at its hottest setting for 15 minutes and then drain the solution. Fill again with just the bottled spring water. Reheat and then empty. After removing all of the water, turn on the iron and let it sit in the horizontal position for a few seconds to evaporate the last of the water. This will not hurt your iron, but will remove all the moisture before storage.
To keep your iron working well, use bottled spring water, and remember to remove all water before storing your iron. Always allow the iron to cool and store it on its heel.
Using the right water will prolong the life of your iron. Commercial de-scaling cleaners are hard on the inside of the iron and can cause leaks. Do not use distilled water, as it is too pure and will not produce much if any steam.
on Jul 14, 2010 | Irons
Brown water spitting out of bosch steam iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Nov 27, 2007 | Rowenta DE-480 Iron
Sunbeam 4039 Iron Logo
1,788 people viewed this question
Top Sunbeam Irons Experts
Henry  Thomas
Henry Thomas
Tony
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
