Always disk boot failure?/ how can i fix it??
  • 86 Answers
Make sure your drive is connected and enabled in the BIOS configuration. also that you don't have any bootable devices in the computer (CDs, USB drives, external drives). Hope it helps.
Posted on May 15, 2010
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
PXE-E61-Media test failure, check cable
That is normal, it is trying to check for a boot from network, and it has probably always made this error message (unless a network cable is plugged into the computer and a switch), but then booted from the hard disk, so you have never noticed the error.
Jan 29, 2012 | Dell Inspiron 5100 Notebook
Disk boot failure
Yes, this is have drive issue. May not be fixable with the restore disk. Test your hard drive to see if it's still in working order.
May 21, 2010 | Microsoft Windows XP Media Center Edition...
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
My Toshiba Satellite L305D-S5895 can't boot. I installed Fedora10
If you get a display or splash screen then you may just have a bad hard disk or memory dimm. If you get nothing then it is a hardware failure beyond a simple fix. Get on the phone with Toshiba and get it fixed before your warranty is up.
Dec 26, 2008 | Toshiba Satellite L305D-S5881 Notebook
DISK BOOT FAILURE
The sata cable\bus that connect the hard disk with the motherboard get loosen up some times. that results in the disk boot failure. if you once remove the sata cable from the harddisk and motherboard and then fix it tightly you can get the system working properly again. if the problem again persist then bye a new sata cable and fix it by replacing the older one, Thank You!
Oct 26, 2008 | Intel Motherboard
Boot failure
Try booting from a dos boot disk or windows startup disk, this will prove that HW is OK
then if it boots OK you may have a HDD problem.
Post back results
Jul 12, 2008 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
