Question about Navman F20 GPS Receiver
Blank screen can get directions but no screen think loose connection but cannot find reciept for purchase not had system 12 monthes yet e.mail janeannwilliamson@hotmail.co.uk
    Problem Solver:
  • 12 Answers
First thing is do you get the start-up screen when you turn it on?
If that appears tro be OK you may have inadvertantly changed the screen brightness.
Remove from the mount and rotate the unit in your hand to the light. Tap once on the screen and then tap where the light bulb icon is. Drag the brightness up to full scale. Also make sure it is not in night-time mode with its brightness turned way down. Not that you would probably suffer the same problem that I had but the screen will go blank and actually give you a thermometer reading if the unit overheats from being exposed to a locked car in full sun, Mine reported 52 degrees Celsius and failed to work until I cooled it down in front of the air-conditioner vents. Of course it was summer and I live in North Queensland Australia! Hope it comes good for you.
Posted on Apr 27, 2008
I purchased a card for twenty dollars at walmart and then relized it was the wrong purchase, when I took it to the service desk they would not refund my money and gave me a number when I called that number...
Walmart does not issue refunds for prepaid phone cards and does not sell post paid cards seperate from phones. If you shipped it back see if you can obtain a tracking number. If you dont have one and sent the item without making a copy of the reciept then im afraid your out of luck. If you have the tracking number and reciept you can contact walmart's HQ at 1-800-925-6278/http://walmartstores.com/contactus/feedback.aspx or send written request for this to
Walmart Home Office 702 SW 8th Street Bentonville, Arkansas 72716-8611. If nothing else and you have the reciept and tracking number contact the BBB online.
Nov 09, 2010 | Cell Phones
Purchased in sept 2009 and screen went blank in oct 09.they replaced it and now its doing the same thing
can you still receive calls even when the screen is blank?
I don't think the screen is the problem of your phone, but a flex problem. This blank screen issue is a common problem with slide and flip phones.
This occurs as a result of constant opening and close of flip or slide phones which makes the flex to worn out.
The flex is the one that connects the screen to the phone main board, and once this flex is weak/worn out or loose contact, there won't be any display on the screen.
Therefore check the phone flex and not the screen. Screen doesn't just get spoilt, except it hits the ground or something.
Take care.
Mar 19, 2010 | Motorola Mobility Rival A455 Cell Phone
Incoming Server ? Outgoing server? Port No. ? I need to set my partners new Samsung mobile fone to receive her emails. Can you help ? Thanks
you need to get in touch with yahoo directly, I think you need to purchase some monthly deal to get the yahoo mail to work outside of the website into phones etc.
Or was it yahoo plus. Something to that direction in any case, it will not work with a standard account, they will supply you with the info.
Nov 15, 2009 | Yahoo Mail
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Was working for 11 months..then doesn't load the disc of any sort
Go to where you purchased the playstation,, they will have a copy of the reciept in there system, due to warranty issues. Yes you will need a copy of the reciept when you send it back to Sony.
1 800 345 SONY is the toll free number to contact them.
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
Laptop freezes restarts or goes to a blank screen
its not the issue with the system
u have a usb printer connected to the system
disconnect that and start the system it should work
Nov 01, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
MY MONITOR SCREEN DOES NOT COME OUT HELP PLEASE
hi Bips07.
Apparently, this model has an Achilles heel...the ribbon that controls screen extension/retraction. I believe Pioneer extended warranties on this model to 4 years if purchased via a pioneer main dealer or sub contractor. Problems normally occur within 18-24 months from new. I assume your unit is at least 18 months old. Best to contact place of purchase or Pioneer directly.
May 21, 2007 | Pioneer AVIC-X1R CD Player
Blank screen on Panasonic Camera
I had the same problem. So I figured I'd take it apart and see what was loose. I removed all the screws around the outside and pulled the back cover off. There is a ribbon connector at the top with a locking cover. The cover was unlocked. I re-seated the ribbon connector and closed the lock and it works now. Let me know if you need more details.
May 22, 2006 | Panasonic Lumix DMC-LZ2 Digital Camera
Navman F20 GPS Receiver Logo
108 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
