Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Schematic wiring diagram of fan motor - Bionaire BSF1731RC Stand (Pedestal) Fan
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
Mar 19, 2017 | Goodman Heating & Cooling
Where can I find a wiring diagram?
If it is just a fan, the wiring is so simplistic that there is no schematic for it. Basically all you have is two wires for the motor with an on/off switch wired in series with one of the two wires.
If a multi speed fan the switch is a tad more complicated but still wired in series.
Sep 04, 2015 | Dryers
Looking for a wiring schematic for a ge dide by side gsl25jfphbs no power ro evap fan motor
The problem you are having is most likely a defective=> WR55X10473 Main Control Board. The defective WR55X10473 Main Control Board may have been caused by a defective=> WR60X10185 Evaporator Fan Motor. If your motor has a white thermistor in the connector you need the related fan motor WR60X10074. If it has a connector for a light you will need a=> WR23X10467 Fan Motor Reason I am telling you this is because if the fan is defective it can again damage the Main Control Board. The same wiring diagram is found=> HERE or HERE by clicking on the wiring diagram. Listen to this video because it explains what I am trying to say. GE Refrigerator Fan Motor Diagnostics If you would like I can walk you through the diagnostic's to see what is going on. I am here should you have questions, Thanks John Tripp Appliance 911
May 17, 2014 | GE Refrigerators
Cooling fan wont come on 1989 mercury sable
First jumpering the fan motor to the battery is a bad idea. The fan will always run even if the vehicle is not running. The fan probably draws enough current to drain your battery overnight. To find the wiring diagram you may need to buy a chilton or haynes manual. If you know somebody who works for a ford or mercury dealer they may be able to get you a schematic.
Sep 15, 2012 | 1989 Mercury Sable
Need wiring schematic blower motor fan switch 1996 suburban mexico build
We do not have any wiring diagrams, they are copyrighted by GM and not free to share. You can access them here: alldatdiy.com
Apr 26, 2012 | 1996 Chevrolet Suburban
Fan not running
Check the fuse and the wiring, can help this diagram...
FIG : Engine Cooling Schematics (2000)
Good luck (remember rated this help).
Mar 10, 2010 | Saturn SL1 Cars & Trucks
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Need diagram to fix motor fan
Go to your local library and look the schematic up in the technical books that you usually can't check out from the library. You will find factory manuals there. You can check the fan to see if the motor is good or bad by jumping power to it. If the motor is good then you probably have a bad thermostatic relay that won't engage the fan when it reaches it's temp limit.
Mar 15, 2009 | 1992 Ford Explorer
Heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
1,097 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
