Question about Motorola Stereo Bluetooth Headphones
Motorokr s9 bluetooth headphones won't recharge
When plugged in to recharge, there is a flashing purple light. When unplugged, the headphones will not turn on. Not sure if there is any fix for this or whether the battery is fried.
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Posted on Jun 06, 2009
  • 3 Answers
SOURCE: Motorola S9 bluetooth headphones
Try 0000 this is standard manufacturing default code for nearly any blue-tooth device that has security feature enabled and because the moto s9 as far as i can see has no way of being able to change this code it must be still at the manufactured setting
Posted on Aug 15, 2009
SOURCE: motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Posted on Nov 20, 2009
fkuk
  • 311 Answers
SOURCE: S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Posted on Dec 27, 2009
SOURCE: They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Posted on Feb 01, 2011
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola S9-HD will not turn on or charge
I had this problem as well, and my issue stemmed from a faulty charger that came with my headset. I would suggest trying to charge your headphones with a different cable. I found that I could charge my headphones with the microUSB cable that connects my laptop to my external hard drive.
Jan 20, 2010 | Motorola Mobility MOTOROKR Bluetooth...
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Pairing Motorola S9 headset with PC
i have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Jan 25, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorokr S9-HD headphones does not pplay music with Fusic phone
On your smartphone, you need to enable the bluetooth wireless headset settings. There may be a seperate setting on your bluetooth options for enable wireless headset and enable wireless handsfree.
You may also want to check and make sure the volume is turned up all the way on the smartphone media player and on the headset.
Jan 12, 2009 | Cell Phones
Motorola Stereo Bluetooth Headphones Logo
132 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
