Question about Kenmore 55603 Side by Side Refrigerator
Freezer defrosted and the fridge isn't as cold
It keeps running and there is a clicking noise from time to time in the back left.
    President:
  • 1,218 Answers
Good day,
The clicking sound is the compressor trying to start and can't. Either the compressor is bad or one of start components pressed onto the pins of the compressor has failed.
There are 2 or 3 components that can be pried off the compressor and taken to an appliance parts house where they will be glad to test them for you.
The 3 components are the thermal overload protector, the start relay, and on some models a start/run capacitor.
If any check bad replace as needed. If they all test O.K. then there is an issue with the compressor which will require the attention of a professional.
Note: If the machine is under 5 years, leave it alone. Call for factory authorized service. The compressor has a 5 year warranty.
Posted on May 15, 2010
4 Suggested Answers
  • 159 Answers
SOURCE: After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Posted on Aug 10, 2007
heatman101
  • 43501 Answers
SOURCE: My side by side fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 18, 2011
imufo2
  • 3773 Answers
SOURCE: My Hotpoint MSZ801(uk) fridge freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
Is there a bearing or bushing on the shaft that the left axle slides onto on a 1999 Bonneville se?
i have been fooled by this one way to many times. when a wheel bearing or hub assesembly is making noise, it will sound like it is comming from the other side. i do not know why this is. but one test will prove if and which one. when growling noise occurs, notice, when turning left or right, does noise get louder and quieter as you turn? if so then it is wheel bearing. when turning left the right side will make more noise. when turning right the left side will make more noise. if always the same then, tires or transmission need addressing. the cv axle does not make a growling noise, unless front wheel drive car does not move, it makes a clicking or poping noise. sorry but at least you dont have to replace other axle
Sep 12, 2014 | 1999 Pontiac Bonneville
My car suddenly won't start. There is a constant clicking noise and the dash lights are going on and off in synch with the clicking noise. It doesn't appear to be the battery. Any idea what the problem...
Sound like a low battery, lights left on or not charging. Try boosting it. If starts and then stalls the alternator not charging. If it starts and keeps running its probably a low battery or a drain.
Jan 05, 2011 | 2007 Kia Spectra LX Sedan
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Fridge is not cooling and making a clicking noise. Checked back panel. cleaned whole pile of dust, fan is running smoothly. clicking time interval has increased, but still not cooling.
Try replacing the compressor relay , which is not expensive , that could be the problem , but if the compressor keeps clicking on and off (overloading) , is probably burnt.
Oct 16, 2009 | Hotpoint HSS25GFP Side by Side...
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I keep hearing a clicking noise every time i drive foward, back right or left. why does it keep making that noise?
Could be cv axles need to be replaced, to have them done usually around $100 - $150 each side.
Jul 19, 2009 | 2002 Toyota Camry
Noise in back left panel.
Sounds like you have rear heat and a/c. The noise you are hearing is the temperature blend door actuator. You can make the noise stop by setting the rear temp to either hot or cold till the noise goes away. The actuator has plastic gears that shear off and it tries to position to the correct setting and it can't. That's why it clicks.
Mar 10, 2009 | 2002 Ford Explorer
Monitor heater model 41 keeps turning off during cold spells (AK)
Can you give us more info? How long does it run before quitting? Have you ever been close when it quits? Do you hear a thumping noise when it quits. Can you see the flame?
Tom Hawkins
hawkins111@gci.net
Jan 07, 2009 | Heating & Cooling
Kenmore 55603 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
