Question about ASUS Eee PC 1000H Laptop
New battery calibration, drain battery, windows will not boot
Follwing instructions with new 12000 mAh battery, full charge followed full discharge until PC powers off. Now PC will not boot fully into windows, it shows the windows login window with the little bar going across the screen for 5 seconds then changes to an error screen that allows selection of windows boot in safe made, last good setup etc. none of which work. Tried reset, hold down off switch, with new battery, without, with old battery, without, no change....
    Guru:
  • 689 Answers
Sounds like OS was not fully installed properly----Reinstall.
Posted on Sep 05, 2010
New battery and only charge to 45%?
My new battery cam with an eight page manual containing instructions got use in a translated (poorly) version of the Chinese original. Of course I did not need a manual to install a new battery and ran into the same problem as you. Refer to the discarded manual and find one and a half pages on how to initialize a new battery.
OOPS JPG came out too small to read so here is a rough OCR
"User Manual on Laptop Battery
Respected users:
Thank you very much for trusting and using our laptop battery. Before using the battery, read this manual carefully. This instruction manual elaborates how to use and maintain the battery correctly. Batteries are consumables, and have a limited service life. However, we can prolong the life of the laptop battery considerably through correct operation, proper charging/discharging and correct storage.
Calibrate your laptop battery to optimize its performance
Inside the laptop battery is microprocessor software, which calculates the battery volume during the charging/discharging. Batteries must be calibrated from time to time to ensure correctness of the time and the percentage displayed on the screen. You must implement a complete cycle of charging and discharging the battery at the beginning of using the computer, and repeat this cycle every two or three months. The charging and discharging procedure is as follows:
1.Set the Power Supply option first: Right click on the screen and select Property -> Screen Saver -> Power Supply -> Power Use Scheme -> Portable. In all the subsequent operations such as When Computer and Use Battery, select Never. Under the Alert option, deselect Alert for deficient battery and Alert for serious battery shortage.
2.Disconnect the power adapter and use the battery until the computer is powered off due to exhaustion of the battery.
3.Connect the power adapter until the battery is charged to 100%. Before initial use of the computer (or resuming use of the computer after long-term storage), the battery must be charged to full.and discharged for 3-4 times to optimize the performance. The charging process takes more than five hours.
Note: When your battery is calibrated and reaches the best performance, set the Power Supply Options on your computer to the default value to ensure that the computer can send correct alerts to you, for example, low battery alert, and alert before the computer enters the hibernation status.
You must discharge the battery to let the computer power off, and then charge the battery to 100% to calibrate it. Then you can connect or disconnect the power supply anytime regardless of the status of the battery volume. Moreover, you can perform a deep charging and discharging cycle under control of the protection circuit in a time"
Sep 12, 2013 | HP Computers & Internet
Tip
NiMH batteries do not have memory effect. However, unlike NiCads, new batteries...
I'm not certain which camera models this applies to, but definitely quite a few:
Many of the camera makers to not emphasize that after your rechargeables become low, you still have to use the "discharge" function while in your camera, to drain them adequately, prior to recharging. Otherwise, the "memory" in the battery on how much charge it can take gets lower and lower. If that has happened, try the "discharge" function, which will restore full charge capability
on Mar 29, 2008 | Fuji FinePix S7000 Digital Camera
I have purchased a new Dr Who sonic Screwdriver wii controller, unfortunately the instructions were thrown out with the packaging and i am having trouble charging it. I have it currently connected via usb...
Hi, Here is the relevant text as found in the instructions:"Plug the mini USB end of the supplied USB charge cable to the charge socket on the Sonic Screwdriver Remote Controller (SSRC) and other end [ their error, not mine -KP ] of the charge cable to the Wii console. A red LED charge indicator is on when charging. When the battery is fully charged, the red LED automatically turns off. Charge time is between 2 to 3 hours and a fully charged battery has between 6 to 12 hours of playtime.""The Wii Console must be ON for the SSRC to be able to recharge its battery. It will not recharge when the Wii Console is OFF or in Stand-by Mode."" Charging : LED lights up"" Full charge : LED goes out"Hope this works for you. Keith Pyne
Jan 29, 2011 | Computers & Internet
I was charging a traxxas 3000 mah battery at 3.0 amps and after 28 min 43 sec it showed a full charge but only input 1334 mah. i have charged this battery only 2 times previously on this charger and...
You are not doing anything wrong, chances are that you just did not fully discharge this battery before charging. You will notice that all batteries will vary from charge to charge, but this is normal. Have fun with the cars. Hope this helps.
May 06, 2010 | Kitchen Appliances - Others
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
I bought KODAK NiMH 2400 mAh and it isn't rechargeable when I recharge it it jus work for few minutes.
NiMH tends to have a "memory". What this means is that the batteries will get used to being only charged and discharged a certain amount. What could be happening is that the battery THINKS it is charged when it is not... or.. it THINKS it is discharged when it is not. You can try to recondition them:
  1. Charge them
  2. reset the charger and charge again
  3. put them in your device and drain them
  4. let them sit, drain them again
  5. recharge them
  6. drain them again
Do this a few times. If you don't notice an improvement, you may want to consider getting a new set of batteries - I would recommend lithium rechargeables.
Jul 11, 2009 | Duracell NiMH AA/AAA Battery Charger with...
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
ASUS Eee PC 1000H Laptop Logo
652 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
