Question about Refrigerators
Westinghouse Virtuoso Fridge - Circuit Diagram
Thanks for responding - the model number is RS662T*11. It's a Westinghouse Virtuoso 660L side by side fridge/freezer and it's tripping when it goes into defrost mode - we are after a schematic for it as there is no diagram or print anywhere to be seen on the fridge. Do you know where we can get one from?
Thanks heaps
  • Anonymous Sep 29, 2008
    I have the same problem.
    Did replacing the Defrost timer fix the problem?
    Problem Solver:
  • 5 Answers
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
  • Ralph Dean
    Ralph Dean Jun 05, 2014
    Could be the RCD, because the heating (defrost) element has absorbed moisture. I have seen that before. The fridge needs to be plugged into something that doesn't have an RCD protection on it, for longer than 24 hours, to dry the element. Gen set? Bypass RCD for cupla days? It often happens after the fridge has been unplugged and not used for a while.
I had the same problem, all that had happened was that the Earth on the backing plate had come loose. Check that too.
Posted on Feb 11, 2010
  • stewart610
    stewart610 Feb 15, 2013
    Wish someone would post a parts diagram or service manual so i could fix it myself
    Scholar:
  • 178 Answers
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Posted on Mar 30, 2008
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
I need a schematic (wiring diagram) for a Westinghouse RE391S-R fridge please
call Customer Service Representatives can be reached toll free at 1 888-523-1930. Get tech support and give them the model and serial numbers. To request to send you a diagram. Nothing on their web site
or email customerservice@westinghouse-home.com
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse virtuoso fridge door wont shut. it is hitting at the bottom. model number RJ525V-R. You have to lift the door to shut it.
SPACER WASHER ON PIN HINGE GON AWOL/REPLACE IT..if can lay unit over to get to screws on bottom hinge of unit underside, awkward/heavy, not on your own please ,this mother is heavy.........
Feb 08, 2010 | Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Circuit diagram for WEstinghouse Virtuoso Side by Side Fridge
It helps us to help you if we have a model number to work with. I have a site called www.mymarcone.com that if I have a model number, I can look up virtually ANY appliance diagram. Please post on this again with a model number and I will do my best to help you.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
2,856 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
