LCD Monitor my hp f2105 lcd widescreen monitor screen goes black after 1 sec when you turn it back on it again stays on for only 1 sec any help would be good, thanks
    Sergeant:
    Champion:
  • 293 Answers
Is it connected to a PC? is the power source good 110v or 220v?
Posted on Mar 30, 2008
SOURCE:
My hp f2105 monitor stays on for only 2 seconds and blacks out again how can i fix it?
The light comes from 4 luminiscent tubes. They are empowered by high-voltage power suppy. There is a circuit, that continuously monitor the lamps and the quality of the power from the low-voltage power supply. Either there is a faulty light tube, or there are inflated capacitors on the LVPS. First one is hard to repair due to need to open the LCD itself, which is hard and dangerous, the light tubes are hard to find and LCD is hard to clean perfectly when closing and appear dirty spots on the screen. The second one is easy - visually inspect the capacitors and if their top is not flat, then replace all of them with the relevant capacitance. I suggest to use capacitors for higher voltage (35V) thus making the PS lasting forever.
Apr 07, 2012 | HP f2105 21" LCD Monitor
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
My monitor won't stay on it will go black after a sec. If you turn it off then on the monitor will work for a second the it goes off again. I have unplugged cords and it still does it. I have a hp f2105
It is "normal" for a monitor to "go black" when it is NOT connected to a computer.
Connect it to a different computer, to see if the video-card on your computer has failed, and to see if the LCD monitor works at all.
Dec 15, 2010 | HP f2105 21" LCD Monitor
HP f2105 21" LCD Monitor is going to sleep after 2 sec.
Try it on another PC so we can narrow down the problem before taking the monitor apart. Please post back. It can be the setting on your PC, vide card problem, need to narrow down first. I will be working a third one of this model tomorrow and I will upload the pictures of what inside tomorrow.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 17, 2010 | HP f2105 21" LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
Screen shows for 2 seconds, then black, power button still on
You could have an inverter problem or a faulty CCFL lamp/s.
For service, parts and DIY info I found LCD Parts helpful, use this link to get to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | HP f2105 21" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Hp f2105 only stays of for 2 seconds
Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
Jan 13, 2009 | HP f2105 21" LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Open Questions:
ICLOUD helpline phone {&$&{[email protected]*1O69} NuMbEr USA This ICLOUD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ICLOUD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ICLOUD USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, ICLOUD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ICLOUD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ICLOUD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ICLOUD USA Calling ICLOUD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ICLOUD USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ICLOUD USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ICLOUD USA's phone numbers against each other. Contacting ICLOUD USA in General While I8OO8O31O69 is ICLOUD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ICLOUD USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ICLOUD USA.
Oct 17, 2019 | Best Computers & Internet
THUNDERBIRD helpline phone {&$&{[email protected]*1O69} NuMbEr USA This THUNDERBIRD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 THUNDERBIRD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the THUNDERBIRD USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, THUNDERBIRD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. THUNDERBIRD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact THUNDERBIRD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling THUNDERBIRD USA Calling THUNDERBIRD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from THUNDERBIRD USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with THUNDERBIRD USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare THUNDERBIRD USA's phone numbers against each other. Contacting THUNDERBIRD USA in General While I8OO8O31O69 is THUNDERBIRD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach THUNDERBIRD USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact THUNDERBIRD USA.
Computers & Internet Logo
101 people viewed this question
Ekse
Alun Cox
