Connection problems with Philips DTR220
Having connected up a Philips DTR220 to get freeview, I cannot access any freeview channels. A message appears saying no signal, check antenae and cable. I've checked and am in a freeview reception area, my tv aerial which was in the attic is now high up on an outside wall but I'm still getting the same message. No problem at all with terrestial tv. Any ideas? Do I need a digital aerial (is there such a thing)?
There is such a thing as a HD areial, but in this case it sounds like you need to point the antenna in the right direction. If your freeview is digital then there is a diredtion the areial needs to piont, and there is a front and a back to it. You need to find where the signal source is located and point the areial in that direction.
Posted on Mar 31, 2008
Slanted screen on freeview connection to Beko 28426DNS,
your television has a defect.the best remedy for this is to resolder the jungle ic. the technician can do this job.
Jun 19, 2010 | Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
I have two problems with my DTR220 freeview digital box. Firstly every night at 11pm it stops working and I have to turn on & off the power to get it back. Secondly, The BBC 1, 2,3 channels...
First I would move the box closer to the booster (amplifier) if its furthest away from it. Do you have another box you can swap out in that location to see if the problem is the signal for some reason? I am not familiar with the boxes but, is it possible at 11 PM they are doing guide updates or possible software updates at that time? I know that here in the U.S. our two satelitte companies do guide and software updates but, those usually occur in the early morning hours of 2 AM. Hopefully that helps.
May 29, 2008 | Philips Televison & Video
Can't record Freeview
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Apr 12, 2008 | Philips VR550 VHS VCR
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
UK TV History Freeview Channel
UKTV History now finishes at 18:00, when it is replaced by a new 'cheap-tacky-repeats' channel called 'DAVE'.  Worst thing Free-view has ever done in my mind.
Oct 17, 2007 | Televison & Video
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
