LG Studioworks 775N  17" CRT Monitor
Problem for LG Studioworks 775N (White) 17" CRT Monitor
Horizontal display
By swasteven on Mar 30, 2008
After about 20-30 minutes the horizontal display shrinks.
Same Problem
Sep 06, 2008
-   I want to play xbox 360 games however when I change the PAL settings to 60hz the screen only displays in black and white. I was told the likely cause was that my monitor an LG was running on 50hz. How do I change the settings to 60hz.
-   Guest
Best Solution
posted on Mar 31, 2008
Helpful)
Gundar
Rank: Apprentice
Rating: 85%, 1 votes
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
Was this helpful?
Yes
No
Solution #2
posted on Apr 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I think this problem appear vertical section. Pl.
cheak vertical section. dry solder vertical section.
Solution #3
Not Rated)
BALACHAN
Rank: Master
Rating: 92%, 22 votes
This complaint normally showing in this model...It's become normal condition on hitting on the top there is dry solder. Otherwise it's reasons may be drysolder or component fail. Go to the nearest service center for service.
Was this helpful?
Yes
No
Popular Solutions for LG Studioworks 775N 17" CRT
Questions and Unsolved Problems for LG Studioworks 775N 17" CRT
Do you recommend LG Studioworks 775N (White) 17" CRT Monitor?
Answer
Answer
I have an optiquest Q19wb widescreen monitor, and after I set it to 1440x900 as suggested, the... (More)
Answer
I have a studioworks 775n and the brightness is at 100% on the OSD but vidios and pictures are still... (More)
Answer
please help me. Lg studio work 775n 17" CRT Top corner problem. Top corner is stretch both side... (More)
Answer
i want data cable for lg studio work monitor, where it will buy in cheenai city near vadapalini
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(168) 454-4153
QABastards
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
