Question about Mitsubishi Televison & Video
I have a 72"projection tv and im trying to connect cctv cameras VGA TO VIDEO INPUT IVE TRIED DIFFERENT WAYS AND WHEN I CONNECT SAME CABLE TO ANOTHER TV IT WORKS PLEASE HELP
  • 566 Answers
Hi jorge
I`m going to help you with your setup but first;
Could you give me your tv`s model number ?
And your cameras : do they have their own power supply or are they fed through the coax/video cable?
Posted on May 15, 2010
  • Jacques Marin
    Jacques Marin May 15, 2010
    Hi again jorge
    Are you having problems replying to this post?
    If so: this comment will send an email to the address that you left with fixya, just open it and click on the link.
    It will bring you here and you will be able to add a comment.
    By the way;
    Make sure to look in the junk mail if you don`t get an email.
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
Can i use my tv as a monitor for my home computer (Dell Optiplex 745)and if so how. I tried difrent ways and cant seam to do it.Help. Please. Chris.
The TV should have VGA input socket to connect with. if have; you can connect the TV with the computer, using a VGA to VGA cable.
VGA input socket.
VGA - VGA cable
25737496-zeccwmaoed3oumaueic5tnov-2-2.jpg http://electronicshelponline.blogspot.com/
Jun 09, 2015 | RCA Televison & Video
HOW DO I CONNECT MY ACER ALL IN ONE TO A TV
You use a HDMI cable to connect to the TV HDMI input and then select that as the input on the TV. The computer side should work once the cable is plugged in to the TV automatically. Acer Aspire AZ3 615 all in one PC review great AIO PC for all the family...
Feb 18, 2015 | Acer Aspire AZ5600-U1352 (PW.SC902.039) 23...
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Can I connect a cctv camera to this and how,where, what source setting
The Speco dome camera has a standard 75 ohm. composite video output so you should be able to connect it directly to your composite video input. It does however have a slightly higher and non-standard resolution (540i vs 480i) for composite video so it could be that the ViewSonic can't upscale it correctly as a true professional monitor can. If you can manipulate the composite input settings through the setup menu to upscale the inputs I'd give that a shot too.
Feb 14, 2013 | ViewSonic N4285p 42 in. LCD TV
How to set up cctv camera video output to Alba 19880HDF via vga input
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Aug 24, 2011 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
