Question about Goodman CLJ36AR42 Air Conditioner
Condenser wont engage
Goodmin clj36
  • 284 Answers
Check the circuit breaker for the condenser be sure it is on?
A outdoor disconnect box near the unit be sure it is on,it may have fuses behind a cover ,need to be sure they are good?
Thermostat set to cool and set below room temperature?
Obvious items to look for and to be more in depth you will need to know how to use a multi-meter to check other probable causes
Posted on May 15, 2010
A/c clutch will not engage after replacing radiator and fan 4.7 03 durango
was air con working before radiator swap out
is the air con fan plugged in
as above no gas in a/ c system clutch wont work
Oct 26, 2016 | Cars & Trucks
Can R410a freon be used with Goodman clj36-1a ac compressor
Can not mix 22 and 410 equipment the blind and pressure is different
Jul 05, 2014 | Goodman Heating & Cooling
Clj36-1a air conditioner NOT cool the house fan turns on
check breakers see ..if you have 240 volts and 24 volts to outside unit if you do replace contactor
Sep 06, 2013 | Goodman CLJ36AR42 Air Conditioner
Does A/C clutch engages for heater as well?
a/c runs to condense moisture out of the incoming air as heater is running so windows wont fog up .a/c clutch will cycle fast when low and when switch is bad,
Aug 02, 2012 | 2002 Chevrolet Cavalier
Goodman CLJ36-1A with bad Copeland Compressor CR30K6-PFV. Any suggestions where to get a replacement compressor?
Not a DIY project. You'll need refrigerant recovery equipment, vacuum pump, manometer, refrigerant scall, refrigerant disposal bottles, high pressure nitrogen tanks and regulators, acetelyn tanks with regulators and torch tips not to mention EPA license. Call a reputable service company. In South Central PA, fair price range is $1,500 - 2,000. If the unit is more than 10 years ole, replace the condenser (if they can get one for your refrigerant) for about $1000 more.
Jul 18, 2010 | Goodman CLJ36AR42 Air Conditioner
Compressor fan
This sounds like it is caused by either a high pressure reset. Or the compressor is tripping a high temperature limit internally. One thing you may be able to do is to hose off the coil surface with a garden hose on the outside (condensing unit) this would allow the operating pressure to drop if it is dirty.
Hope this helps Ya
Jul 06, 2008 | Goodman CLJ36AR42 Air Conditioner
Goodman CLJ36AR42 Air Conditioner Logo
96 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
