Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Water leaking from the bottom of the big PVC pipe parallel to the water heater
  • Randy Marshall May 15, 2010
    Is the pvc connected to water heater?
  • 494 Answers
What is the leaking pvc pipe connected to? The T & P valve on the side (or top) of the tank? Or is it an incoming cold or outgoing hot water line? If you have just lit the water heater, the T & P valve may drip, but only for a little while and it will stop. The T & P (temperature and pressure relief) valve may be bad and need replaced. Turn off the incoming cold water valve and turn the gas valve to off position. Then drain the water heater using the T & P valve, it will stop draining when the water level is just below it. Remove the T&P valve and replace with new one. Use thread sealing tape on threads. Or call a plumber if not sure.
Posted on May 15, 2010
How to get hot water faster? is there a mixing valve that can fail and prevent fully hot water from coming?
When the lime is piling up on the heater's floor, it clogs the supply pipe. that is the result of low water temperature. Remove the lower valve or heater after draining the water and clean the bottom part with a piece of PVC pipe.
Nov 29, 2015 | Water Water Heaters
What is the max flue temp for a rheem xg50t06py42u0 water heater. High flue temp is distorting the pvc flue.
PVC pip manufacturers DO NOT recommend PVC pipe for flue gases. Some gas appliance manufacturers do, but this is no guarantee of safety. Here is a link to an article you may find informative on the the subject.
Using the fireplace can melt the heating systems PVC vent in another flue...
Nov 02, 2015 | Rheem Water Heaters
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
I have a Rheem B33325 hot water tank, it is leaking from the pvc pipe that runs down the side of the tank. Help!
Sounds like TP valve is leaking:
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-replace-TP-valve.html
Do not cap off TP valve.
Raise lever and gently lower back down to see if TP will turn off
Replace TP valve.
If problem persists, re-post question with specifics about your tank: such as electric, or gas, and if unit has a blower on top, and if gas control valve is electronic or has a dial.
Aug 10, 2011 | Rheem Water Heaters
MY GE PRESSURE RELIEF VALVE HAS JUST STARTED LEAKING. WHAT SHOULD I DO ? GE SMART WATER HEATER GELN0705CO3984
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
Jun 14, 2010 | Water Heaters
Water on flour of water heater
If your water tank is leaking, is it dripping from above or actually leaking thru the bottom?. Can you find the source? Feel around and try to find wet spots above and around it. If it's not leaking from the water pipes or T&P valve, it's your tank leaking. You'd be wise to have it checked out in the morning, before it gets worse. Hopefully your catch pan has a pipe attached to divert water to the outside or to a sump pump or floor drain. Water heaters do sweat, but you can tell the difference if it continues to leak for several hours.
May 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The pvc y draining pipe is leaking water
This needs replaced. You can find the parts at your local hardware store.
Apr 05, 2010 | Fasco Bradford White Hot Water Heater...
The pan at the bottom of the water heater is leaking through the attached valve. Do I need to call the plumber immediately or is this normal? The water heater is still producing hot water.
Now, the pipe that leads from the base water pan should lead to the wall where the water can go outside. If you see water in it, but very little in the pan, then you have water from outside (rain or water hose) coming inside the house. You should have a valve, usually on the side of the water tank near the top that looks like brass with a silver 'flip' handle on it. There may be some plastic pvc pipe attached to it as well. If the water is coming from this valve then you need to have the valve replaced. You may get some extra time by gently tapping the valve where the handle is attached with a mallet so that the valve seats itself. This valve is a pressure release valve. If the water in the tank gets too hot or water pressure gets too high, this valve will open to relieve that pressure. it doesn't happen often, so if this is the first time you have seen it and it doesn't seem to be leaking any more, I would not worry about it. If it is still leaking, you can get a replacement relief valve from your local Lowe's or hardware/lumber yard. They usually cost less than $20 USD
Mar 29, 2009 | American Standard Water Heaters
Water heater ground
You have clearly lost your ground due to PVC. One solution would be to run copper ground wire from the hot water tank to the metal splice on each end of the PVC. It is not necessary to go all the way back to the breaker box.
Jan 23, 2009 | Water Heaters
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
191 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
