Question about Waterway Clear Water 22" Sand Filter System with 15hp Pump 2 Speed
When do i use the bypass to waste position - Waterway Clear Water 22" Sand Filter System with 15hp Pump 2 Speed
  • 990 Answers
Mostly just to drain some water out of the pool if it is too full.
Posted on May 15, 2010
What is error P7 on Canon MP250 printer?
Please refer to this video, to fix it:
https://www.youtube.com/watch?v=HvBpioLPm3M
Inkjet printers has an "ink absorber" counter in which when it has reached a certain level that error will occur. Because when you are printing, some parts of the ink become waste ink & goes to the internal "tank" inside the printer where they are dried. The ink absorber counter tells you that the "tank" is nearly full which might flood the internal parts of the printer and damage them, causing short circuits.
However, this error could be bypassed by resetting the printer as described on the video.
Another better solution is by installing an external waste ink tank to channel the waste ink outside the printer to avoid internal damage. The P07 error will still occur, however you can bypass it.
Apr 28, 2014 | Office Equipment & Supplies
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
We have a hayward 244t sand filter. I was trying to learn how it works. I was trying to vacuum the pool but all the trash is coming back into the pool. What do I do?
For regular vacuuming, these pool filters should be set to the "filter" setting filter control valve. However, if you have a heavy load or the debris seems to be coming back into the water, you can try vacuuming with the filter set to the "waste" position. This will bypass the filter and vacuum directly out to waste.
Mar 13, 2011 | Hayward SAND FILTER, PRO SERIES
On filter and back wash the kreepy krauly slows down stops, but on waste and bypass it works normal
This description would indicate that your filter (whether it is DE or SAND) is causing a pressure build-up that is keeping the full flow of water from being able to travel through the plumbing.
You should check your filter media and replace if necessary.
Even if the media looks good, there are "laterals" in the bottom of the tank that can get clogged as well.
When you are bypassing or wasting, you do not have the restrictions of the sand filter and its components, which is why it is working in these modes.
If this helps, please vote positively for me here.
Nov 01, 2010 | Pentair Kreepy Krauly Inground Automatic...
My talon laggs power..when i first bought the car it was great..off the stop i would gas it and rite at 3000 rpms you would feel the turbo kick in and sink u into ur seat but now i drive it and it just...
the waste gate solenoid could be stuck in the open position causing the exhaust to bypass the turbocharger and not spool up causing the lack of power, so remove the turbo and check the exhaust outlet chamber and make sure that the gate isnt open
Jan 25, 2010 | 1995 Eagle Talon
The DC12 started jamming/stopping on the second sheet from the bypass. The sheet goes into the machine and when I remove it it has about 2 inches of image transferred from the drum. Error Code...
dude... if its jamming on the second sheet from the bypass then the feedroller in the bypass needs to be wiped down with rubbing alcohol... that should make it sticky enough to work...
Dec 12, 2009 | Xerox DocuColor 12 Color Copier
It says on machine reset waste toner . How do I do that?
To replace waste toner 1 or 2:
Open the front cover slowly with both hands.
Take out new toner from the bag.
Remove the waste toner slowly from its position by pinching the lever and pulling the handle. Be certain to hold the toner in a level position. Insert the new one in the same position.
Now, to reset waste toner (if toner 1 or 2 is out of position), just remove and reinsert toner.
Hope this helps.
Jul 16, 2009 | Ricoh Aficio CL5000 Laser Printer
Service required. Parts inside your printer are at the end of their service life.... Can I temporarily bypass this? It is locked.
You can bypass this termporarily by resetting the waste ink counter as described here:
http://www.continuousink.info/forum/viewtopic.php?t=4141
That link also provides information on how to resolve the more long term issue of further waste ink build up. In short you will need to think about redirecting waste ink flow to an external tank or get the printer serviced to replace the pads.
Hope that helps.
Martin
Jun 24, 2009 | Epson RX620 All-In-One InkJet Photo...
Waterway Clear Water 22" Sand Filter System with 15hp Pump  2 Speed Logo
90 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
