Why do i have a large black screen on my tv
Why do i have a large black scree on my tv ,mitsubishi wt-46809
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
You have turned on the closed captioning in the menu by mistake, go back and turn it off and the captioning black box will go away for sure!
Posted on May 15, 2010
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809
When you press the Volume Up/Down buttons does it show anything on the screen (like the level indicator bars...)?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi tv model wt 46809
Good Day, sam;
Sam it depends on "smudge".
If it's an oily type; then a mild soap, like dawn, on damp, warm soft cotton type cloth may remove it.
There are products found in most large best buy, circuit stores that sell a screen cleaner. It's sold in a small spay bottle, about 2-3 ounces. Always spray onto cloth NOT screen. Always wipe/clean with up & down strokes, NOT side to side or at an angle.
If the screen is smudged after attempts of trying to 'cleanning' a scratch, then only replacing the screen will fixya problem, cost will be in the range of $100.00-$250.00.
Good Luck, hope this was helpful, big IRISH.
Jul 15, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Apr 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Thanks for your help with the Mitsubishi WT 46809 but, there is more:
Fuses and IC's are soldered in on large PC board in center of chassis....
Your model is a tight fit that is usually repaired by chassis pull first, then
board repair, normally by a skilled Mits tech........
Oct 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
