Question about RCA F19251GY 19" TV
How can I switch the source from cable to Yellow/Red/White input without the remote?
    Problem Solver:
  • 5 Answers
TRY USING THE CHANNEL DOWN BUTTON. THIS IS NOT A GUARANTEE THOUGH,YOU SHOULD GET A GET A REMOTE AS THEY ARE PRETTY CHEAP.
Posted on May 15, 2010
Have a Roku LT. Plujgged in red yellow white on Roku and tv. Turned TV on.Hit OK on remote. Nothing happened.
Please make sure to set the input source of your TV to the correct source... since you're using Red Yellow White cable, select Video.
Dec 27, 2013 | Roku LT
How to switch tv to play games
well there should be an option on your remote labled either source or input. that allows you to change from the iputs on your tv. you need to know which input you plugged your wii into. if you select the option and match your tv input to where you plugged your wii into and you still have no pic.make sure your wii is powered on. as well make sure you plugged the cables in correctly. if your using componet cables its red green blue for video and red and white for audio. make sure the audio and video are not crossed that will cause pic distortion. and if your using composite cables makes sure its red yellow and white plugged into red yellow and white. yellow is for video and red and white are your audio. if all this is correct and still no pic. then it's either your wii or your TV.
Aug 20, 2012 | Toshiba 30HF66 30" TV
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
I can hear the tv but no picture.. i remove the red, yellow, and white cord from the back of the tv to dust...pls help.. Apex tv brand
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV.
* Plug the RCA cables(red,yellow,white cord) to the designated ports.
* Grab your Apex TV remote and attempt to cycle through the video inputs by hitting the "Input" button at the top of the remote multiple times.
* If you have used a DVD player or similar external device recently, you may have neglected to switch the video input back to the one assigned to your TV programming.
* Devices such as DVD players often reside on the AV 1 or AV 2 video input, and failure to switch back off of one of these will result in a dark, soundless screen when attempting to view cable or satellite television.
* Cycle through the inputs until you land on your cable/satellite input once more, which should result in an immediate restoration of picture and sound.
* If it does not, approach your Apex TV and look over the A/V cable connections. The A/V cable has two sets of prongs, one on either of its ends. Each prong is either red, yellow and white, and plugs into corresponding A/V ports on the back of the Apex TV and the back of your cable or satellite box. Make sure the ports and prongs are color-corresponding and have not been switched up.
Thank you for using FixYa. Keep me posted. :
Mar 12, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I have a blu-ray disc player. Model Bd-C5500. It seems to be telling me I am not connected to HDMI cable. I have connected the cable to the HDMI out terminal on the rear of the player to the HDMI in on the...
HDMI and the red, white, & yellow cables are two different sources. Try using the remote to switch playback source from HDMI to the other choice not sure what Samsung calls the red, white and yellow connectors. I can tell you that the red cable is audio right, the white cable audio left and the yellow is the video.
Jun 28, 2017 | Sony HESV1000 200 Disc Blue-Ray Server
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
Televison & Video Logo
103 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
