Question about HP OfficeJet 6110 All-In-One InkJet Printer
All copies and scans come out slanted???
All my copies and scans come out slanted???
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
How do i get a manual for TI-60 calculator
Request a copy of the manual from http://www.datamath.org/Sci/Slanted/TI-60.htm
The request button is in the lower-right of the first table on that page.
Jun 05, 2014 | Texas Instruments Office Equipment &...
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
My konica 1015 copier is starting to copy very fuzzy on 1.0 size, but on bigger or smaller size it copies fine
Violated adjustment 1 mirrors. Vpolozhenii 1:1 зпервое mirror occupies the invalid position. Do clear optometrists and check the position scanning device in position 1, can be not in its place from for obstacles or slanting. Attentively examine the device, remove glass and slowly move, must be всободный move and return in положенеи 1 on перекритию sensor. This does without stekla. move different scales and arouse to find not faithfull position in scale 1;1
Oct 02, 2009 | Office Equipment & Supplies
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
AR-206 copying problem / paper comes out slanted
There could be somthing in you ADF that is keeping the copy from going in properly. Your tires could need cleaning or there could be something going on with a component in the ADF.
Sould have a technician inspect the ADF to see if it needs cleaning or parts.
May 30, 2008 | Sharp AR-207 Copier
Copying problem
check paper through paper cassette, then through bypass,if fault occurs on both, it is possible the registration roller area is possibly faulty.
There are other reasons for this relating to image formation, but please start with paper feed.
Jan 29, 2008 | Sharp AR-207 Copier
HP OfficeJet 6110 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
