Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
All lights flashing
Changed all the ink cartridges in my Epson RX425. First time I tried to use it there was a strange whirring noise and all the lights flash on and off with an E symbol in the window.
  • nicbark Apr 01, 2008
    Tried cleaning everything I can see. The ink cartridges moves acrossbut then a white plastic square drops down and blocks the ink from moving. That is when the rollers whirr and all the lights come on.
  • Anonymous May 12, 2008
    habe das gleiche problem
    Problem Solver:
  • 7 Answers
Re-check the head if you placed some of the inks incorrectly!!otherwise for service!!
Posted on Apr 04, 2008
  • 61 Answers
That noise was the head belt out of place have a look at the parking carrage you will see a sensor make sure its clean
Posted on Mar 31, 2008
    Problem Solver:
  • 7 Answers
May be need service i have software for new epsons and old epsons contact me
Epson RX425 Ink Cartridge problem
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jan 02, 2010 | Epson Stylus RX425 Multifunction...
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Cyan Cartridge not working
Show empty or not recognized (cross sign)? Check connector at chip and at head carriage. Do replacement procedure form status monitor (how to..). Do replacement ink tank one by one with cyan ink first.
Jul 25, 2009 | Epson Stylus RX425 Multifunction...
Epson RX420 has all lights flashing + E in the display, Have just changed ink cartridge and problem occured
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
May 05, 2009 | Epson Stylus RX425 Multifunction...
All lights flashing
You need to replace the ink pad of your printer.
Please visit epson.com/ipr to get the ink pad reset utility. The software runs on win xp and win vista.
If you need help in replacing the ink pad, please log on to epson.com to find an epson certified servicer near to your area.
Apr 27, 2009 | Epson Stylus RX425 Multifunction...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson stylus photo rx425 says there's no inkbut there is!
try re-install cartridge and chcek connection on the inks and with pc
Aug 13, 2008 | Epson Stylus RX425 Multifunction...
Change of ink
plz power on your printer and wait for some time when the printer becomes stable(no noise) then you open the front door then the printer carrier will come and rest in the middle just take out the cartridge you want to change and replace with new one.
Jul 18, 2008 | Epson Stylus RX425 Multifunction...
Epson Stylus Photo RX425 making a dragging noise
Put to change cartridges remove them and carefully replace them.
No what?
Dec 25, 2007 | Epson Stylus RX425 Multifunction...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
142 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
