Question about Lowrance X52 Sonar Fishfinder Without Transducer
Does the lowrance x510c have a internal fuse - Lowrance X52 Sonar Fishfinder Without Transducer
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
Tip
Lowrance X515C Manual Download
Download Lowrance X515C Manual
Models: X510C / X515C
Have you misplaced your Lowrance X515C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
__________________________________________
on May 06, 2010 | Boating
Tip
Lowrance X510C Manual Download
Download Lowrance X510C Manual
Have you misplaced your Lowrance X510C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
How can a lowrance 5300 globalmap iGPS be used as a fishfinder.
Sadly, the 5300 does not have fishfinder/depth capability.
If you require it, the link below is for the owners manual for your unit.
Sorry I couldn't have given you happier news.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5300ciGPS_0152-191_120506.pdf
Feb 24, 2015 | Lowrance Globalmap 5300c Igps 5" Screen...
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
X510c most of the time it reads 1.6 for the depth, it flashes 1.6 then it will go to the correct depth for a shqrt time then get stuck on 1.6 again some times other depths but mostly 1.6
Does this occur at any depths...over 20ft even.
The X510c will have problems keeping depth in shallow water...especially if it is muddy, weedy down there.
If the problem occurs even in depth over 20ft, then try resetting the unit:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you see the depth (flashing or not) in the top left corner.
If the problem still occurs, make sure the transducer is clean and still mounted so that it is sending the signal straight down to the bottom.
If the problem still occurs, make sure the power is good. You can have the voltage displayed on the screen through the overlay data menu.
Does the problem occur at any speed? If the problem clears up when you stop or slow down, the problem is due to cavitation and the transducer will need to be moved to a location where it is in a smooth flow of water at all speeds.
If none of this helps, there may be a malfunction with the X510c. You can try to update it but you will need to get the software update from someone at Lowrance support and then find a way to connect your X510c to a Lowrance unit that has a memory card slot via a NMEA 2000 network. I can help you with this if you need.
Other than that you can have the X510c returned to the factory for service.
Jul 09, 2009 | Lowrance Boating
My lowrance x510c will not power up
This is a typical example of a faulty display unit,best solution is pack it up and return it,its a faulty internal power pack.
Apr 05, 2009 | Boating
My lcx15mt will not respond. How do I reset it?
check internal 5 amp fuse.  Take screws out and open unit.  Fuse is in the middle of the circuit board.  It is a regular 5 amp automobile fuse. Bob W.
May 02, 2008 | Lowrance GPS
Lowrance X52 Sonar Fishfinder Without Transducer Logo
104 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
