Question about Maytag Neptune MDE5500AY Electric Dryer
Squeeling sound - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryersqueeling sound - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
What type of sounds does a 1999 nissan maxima makes when the back brakes are worn out
Squeeling first if it has squeeling tabs. there to let you know the brakes are getting low but if totaly worn out metal on metal grinding sound.
Jun 22, 2012 | 1999 Nissan Maxima
Loud squeeling noise. Sounds like a bearing.
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
I have a 2001 Sonata. I have a squeeling pulley.
It sounds like you have a worn or streched belt making the sqeeling noise. Whenever you turn on a
device in the car that draws a fair amount of voltage
ie. a/c or headlights it will cause increased drag on
the alternator and if you have a loose/worn or glazed
belt, it can slip around the pully making the squeel.
To adjust the alt-a/c belt loosen the mounting bolts
on the tensioner, then use the adjuster bolt behind
the tensioner pully to loosen and tighten the belt.
Be sure to check the belt for cracks bald spots etc.
While the belt is loose spin the pullys to make sure
they all spin freely. Also I would replace the belt just
to be sure. Hope this helps
Jul 04, 2010 | 2001 Hyundai Sonata
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Maytag Neptune MDE5500AY Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
