Question about Singer CE-100 Futura Computerized Sewing Machine
Picking up bobbin thread
Unless I lower the needle to a position lower than it is supposed to be inserted, the device in the bottom will not hook the top thread and therefore will not grab the bobbin thread and doesn't stitch. It was running fine but then just stopped picking up the bobbin thread in the middle of a design. This also happens if I try stitching using regular sewing instead of embroidery. I have tried different needles, fabric, etc. It is running now but I am afraid having the needle inserted improperly will cause another problem in a middle of a design the bobbin ran out. I replaced it it knotted up bobbin casing came out, I cleaned it and put casing back in , now machine wo't pick up bobbin thread.
  • Anonymous Mar 13, 2014
    The needle is not picking up the bottom thread and no stitching is happening
  • 106 Answers
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Posted on Mar 30, 2008
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
Does anyone have an idea of what might be wrong with my sewing machine? The bobbin thread is not being picked up by the needle.
rather sounds like the people that repaired it did not check the timing the bobbin has to be in the proper position when the needle passes it so the threads cross over .
Aug 10, 2015 | Singer Sewing Machines
The bobbin thread isn't being taken
You state that the bobbin thread is not being picked up by the needle, have you had one or two jams whilst sewing if so then I'm 99% sure you have knocked the cotton pick up hook out of timing potion, the shuttle bobbin sits in the hook case and as the hook rotates in the correct rotation the needle is at it's lowest point and at the same time the pick up hook should just about to go behind the needle as it starts to rise and it's at this point on the way up that the bobbin thread is being picked up, so if the timing as been knocked out of potion it as to be rotate with a little force whilst holding the and wheel and the needle in it's lowest position so that the hook is just and only just going behind the needle and that's it give it a run, normally I would say slacken the clamp screws that secure the hook assembly onto it's shaft, but you can usually get away without doing this it saves time and hassle. Hope you can understand what I have put down as instructions for resetting the hook if it's the case of being out of position.
Happy Sewing
Mar 04, 2015 | Sewing Machines
I can't get my needle to pick up the bobbin thread I have change needles and re threaded my machine and rethreaded my bobbin please help
make sure the bobbin is turned in the right direction and also make sure the needle is inserted correctly into the needle holder, then see if it will pick up the thread and if not your machine could have a timing problem
Oct 22, 2014 | Bernina Bernette Deco 600
Bobbin thread won't pick up when attempting to sew?
Check needle to insure it is not bent.
Check thread tension .
May 13, 2014 | Michley Lil Sew Mechanical Sewing Machine
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Won't pick up the bobbin thread
try changing the needle
try rethreading the machine top and bobbin
make sure the bobbin is inserted and turned the right way in the
bobbin case.
it's also possible that the sewing machine could be out of time and
needs to be checked.
Nov 12, 2012 | Brother Sewing Machines
Needle doesn't pick up bobbin thread
try rethreading the machine -use every thread guide
change the needle--make sure it's the right one for the fabric
your sewing
take the bobbin out & reinsert the bobbin into the bobbin case
make sure the bobbin is turned the right way when inserting it
if these suggestions don't help then the machine need to be checked
here a link for a free manual
http://www.singerco.com/uploads/download/549_7469_efs.pdf
Sep 08, 2012 | Singer Confidence 7469 Mechanical Sewing...
Needle not picking up bottom thread. Whilst sewing thick fabric my needle broke.i replaced the needle but it was not picking up the stitches evenly. I put it away got it out today cleaned the bobbin race...
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Jan 16, 2010 | Janome Jem Gold 660 Sewing Machine
Singer CE-100 Futura Computerized Sewing Machine Logo
335 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
