Question about Kenmore 98702 Stacked Washer/Dryer
Noisy dryer I have a stackable Kenmore washer,dryer.In the dring mode it makes a ton of noise.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryernoisy dryer - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
If your dryer is noisy, check these:
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
Washer noisy while spinning
You probably have a balance problem. You will have to get a service tech to replace the shock absorber/stabilizers (there are 3) in the unit.
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Drum shakes
check to see if you removed the shipping braces refer to your owners manuel
May 25, 2008 | Kenmore 43142 Front Load Washer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
235 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
