Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE refridgerator will not run - GE (PSS26MSRSS) Side by Side Refrigerator
  • heyenz57 May 15, 2010
    I tried motherboard already no luck , light is blinking above water dispenser button , lights inside work .
  • GE Master
  • 4,654 Answers
If lights are on and nothing is working that usually points to the motherboard. If you would like to do it yourself I can show you what to look for and where. As always unplug before working on anything electrical. Will you please confirm that your model is the PSS26MSRSS so I can be sure to point you in the correct direction? I also want you to remove the panel over compressor area and feel the top of compressor for overheating. Let me know when ready. Thanks, Sea Breeze
Posted on May 15, 2010
  • 2 more comments
  • John Tripp
    John Tripp May 15, 2010
    Click Her=> GE ARTICA PROFILE TECHNICAL INFORMATION you will need the information on this page if you want me to help you through this. By clicking on wiring diagram on that page you can download the service manual.
    Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
  • John Tripp
    OK. unplug and look at back of board and then we move down to compressor to check voltage there. The stang thing is when the fans and compressor will not come on that points to the motherboard. The page I sent you has diagnostics we can do by phone and there is no charge. I don't mind helping you. Just go to my forum and on home page has all info you need to contact me. It will be easier to understand that way. Forum=> Appliance 911 Thanks Sea Breeze
  • John Tripp
    Just the fact that the light is blinking at dispenser sounds like low voltage failure on motherboard. This is from that page above the WR55X10942. If you feel better doing this here will be OK. Do you have an OHM meter or voltage meter?
  • John Tripp
    Unplug fridge and place a jumper between J11 and J8 and replug in. If board is defective the jumper may just sart compressor only. The fans run off the top of board on low voltage side. If low voltage is not on the board cannot tell relays to open or close. Sea Breeze
Where is the power button on ge arctica refridgerator model PSs26mgtb/ww
There isn't a power button that I know of on that model I know that it will stop running if the control board shorts out
GE Refrigerator Main Control Board WR55X10942
Aug 06, 2016 | GE Refrigerators
The fan on my GE TFX25ARAA refridgerator stops running, but if I give it a push with a pencil, it starts running again. When it is not running, the outside of the refridgerator gets very hot as do the...
Possible that the fan is defective or the fan is receiving low voltage so as not to run by itself.
you will need to remove the fan and check with an external voltage to see if the fan starts without an external trigger.
If not check the voltage to the fan , trace for any loose connection or poor joints for loss of voltage.
Oct 28, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Jan 29, 2009 | GE Refrigerators
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
