Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Mouse is considerably over sensitive. Every time I attempt to describe the mouse, there is never any record of the "N/M" R0006, PID LZ938AK, & P/N 01-001100. Problem!!!
    Genius:
  • 1,189 Answers
  • Hi, click on the "Start Button," next in the (right area) click on the "Control Panel," in the window there will be "listings" different categories; choose the "Mouse," from the "Hardware and Sound" click on it to open the next window. In this window, if its not showing the Buttons category at the top of the window , select it by clicking on it; there should be a (Double Click Speed) area somewhere in the middle from your point of view, adjust the speed and try it out a few times until you are satisfied with the movement. You can always go back and change some of the other movements available. I suggest, click on the "Device Setting" button, next, once the window open, click on the "Setting" button just below the "highlighted" (Name of the device TouchPad, or maybe different Name). Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished." Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks."
Posted on May 15, 2010
Cursor is jumping all over the screen before you can point at what you need - Dell D620 - Windows xp pro
Firstly try a different mouse to find out if the mouse is the issue - If so a new mouse is probably needed (assuming you cleaned the trackball/laser - video instructions can be found below)
If the mouse is not the issue, then enter mouse settings on Windows XP, and try adjusting the sensitivity etc. This can be done by going to Start -> Control Panel -> Mouse and adjusting "Pointer Options"
If this fails, try downloading drivers for the mouse (assuming it is optical).
Mar 02, 2011 | Computers & Internet
The mouse goes in the opposite direction from i where i'm trying to navigate it.
Check whether you have switched the Primary and Secondary buttons of the Mouse. Please click on Start>Control Panel>Hardware and Sound>Mouse. Then Uncheck the Primary and Secondary buttons of the Mouse to resolve the issue.
Mar 02, 2011 | Logitech Cordless Mouse
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
Where do I replace the battery for a cordless mouse that came with my MK300 keyboard
Q: Changing the batteries in my MK300 trnsp.gif 13634.1.0.jpg How do I change the batteries in my MK300?
Wireless Desktop MK300
Model Number:
Y-R0002 (Keyboard)
M-R0006 (Mouse)
trnsp.gif Battery Requirements:
Keyboard:
  • Requires 2 AAA alkaline batteries.
  • Expected battery life is up to 15 months.
Mouse:
  • Requires 2 AA alkaline batteries.
  • Expected battery life is up to 8 months.
Installing New Batteries
Install the batteries for your mouse and keyboard by making sure the batteries face the correct direction as shown in the image below.
Battery Replacement Tips
  • For best battery performance, always use quality alkaline batteries.
  • When replacing batteries, make sure the replacement batteries are new and are within the manufacturer's expiration date.
  • Do not mix old and new batteries.
  • Do not mix batteries of different brands.
  • Do not use rechargeable batteries in this product.
Jul 25, 2010 | Logitech Cordless Mouse
When i start up my acer note book, it's like the mouse is over sensitive &, doing things on it's own. after awhile this stops/settles down. could it be the temperature? my apt is pretty cold. i have...
Go into your mouse properties(Click on start,then control panel,then mouse)See if you can adjust the sensitivity of your mouse pad.If you can't ,you can always use a USB mouse.
Apr 09, 2010 | Acer Aspire 3680 Laptop
What are the Pros & Cons between a ''Optical Wireless Mouse'' and a ''Laser Wireless Mouse''
The difference between a regular optical mouse and a laser mouse is the light used to track movement. A regular optical mouse uses an LED light in the optical engine, while a laser mouse uses a laser to track movement. The more dots per inch (dpi) a mouse can track, the more sensitive and accurate it is. A typical optical mouse tracks between 400dpi and 800dpi, while laser mice track more than 2,000dpi. Neither is really better; it all depends on your needs and preferences. Unless you're a gamer or a graphic artist with a need for precise movement, you'll probably find a 2,000dpi laser mouse too sensitive. Many gaming mice, however, allow you to switch sensitivity levels so that you have precision when you need it but can revert to 400dpi or 800dpi for regular mousing. Besides their tracking speeds, laser mice work on nearly every surface, whereas optical mice may experience trouble tracking on black or shiny surfaces.
Nov 27, 2009 | Computers & Internet
Touch pad too sensitive, it always messes me up when I'm typing
You could try adjust the touchpad settings. Sometimes there is a touchpad icon in the taskbar that you can right click on to adjust the properties. You can also disable the pad and use a USB mouse instead.
Sep 11, 2009 | Sony 4-660-223-01 Touchpad Keyboard
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
231 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
