Question about Refrigerators
Broken the "defrost element" to whirlpool fridge frezer-wrn38rwg6. got it out, just need a new one. dont wanna pay 200 bucks to get one fitted! can u help cheers Tim
  • 813 Answers
U have to with a frize service tacnision dont take risk its batter 4 u do at ur self have to do more expancive to at ur home so dont take risk go with a good tecnision
Posted on Mar 30, 2008
SOURCE:
Hi. You answered a question about a "sizzle" noise coming from the freezer of a GE Profile side-by-side. Your answer was "The sizzling in your case means that it is working....it is just...
the defrost cycle happens 1-2 times in 24 hours usually, and lasts 20-30 minutes.at which time the cooling process starts again.you may or may not hear the sizzle during the 20-30 minutes.if the frezer-freezes and the fresh food section is cold enough its probably o.k.
Mar 28, 2011 | Refrigerators
I have a Maytag MZD2766GEW ref/freezer that the freezer works, but the fridge is warm. I removed the back panels and the coils were all froze over. I am trying to test the Defrost Control Board. How do I...
in most cases its not the defrost board test the defrost element/s make sure they are not blown test at both ends like a fuse you should get a resistence rating of around .2 ohm if the curcuit is open then the defrost elements need replacing maytag have very reliable defrost control boards they dont fail all that often
best of luck
please take the time to rank my reply
Dec 01, 2010 | Whirlpool Refrigerators
Freezer and drain freezing up
you either have a blocked drain in the freezer or a bad, failing defrost element, timer.
If you have a manual for you fridge you can locate the place to check for blockage in the drainline. I you dont have a manual you can check online at searspartdirect and locate one.
The heating element for the defroster is located right beneath the freezer coils so you need to take the inner panels off the inside of the freezer to get to those.
You can replace the heating element and timer fairly easily. You should be able to buy both of them for around 90-100 bucks if necessary. But try clearing the draining first. You can test the line by defrosting the fridge and pouring some water into the drain and see how quickly it goes into the drainpan below the fridge.
Good luck and be careful.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Wrn38rwg6 frige has decided to not cool properly
My first thought is it defrosting? Look into rear of the freezer and see if ice is building up on rear wall of freezer. If yes manually defrost and let me know what you find. If no I would want you to feel compressor for overheating or look and see if a fan has stopped working while compressor is running. Sea Breeze
Feb 20, 2010 | Refrigerators
Whirlpool S21S4D Ice maker stopped working Now fridge stopped working Frezer OK Defrosted ice on condenser and fridge working for time being! Do you think its the mother board?
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Feb 04, 2010 | Refrigerators
Frezer side working but fridge side not working and all my food gone off
Your refrigerator has possibly stoped defrosting and this is the symptoms and first signs. The defrost control board is located inside the temperature control panel and usually is the part that causes the defrost to stop. You need to unplug and inspect or defrost your freezer. Have a look at the defrost elements to make sure they are not burned out, The part number for the defrost control is W10135899 Let me know if you have questions or need more assistance . at [email protected] Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Whirlpool REfrigerator Freez WRN38RWG6 How do you stop water
Turn Fridge off,leave open for 24 hrs,then shut doors and start.The defrosted water had frozen up high and the fridge then leaks
Mar 01, 2009 | Refrigerators
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
No cold coming to fridge or freezer
I woud say your heater has malfunctioned and it has frozen your fridge, you will need to remove the inside plastic wall on your freezer side if its side by side and get a blow dryer and melt all the ice if this is the case. You would need to change the heating element which defrosts your freezer/fridge everyday to prevent freezing up. You can get this heating element from an appliance store where all the appliance repair people get them specific to your model. Its less than a hundred bucks.
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
