Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Freezer not freezing ,fridge not cooling ,no ice build up around coils.what should i check for next?
    Problem Solver:
  • 8 Answers
Is the Compressor Running? Put your hand on compressor and see if you feel a vibration or if it is cold or hot. On the side there is a start relay. Remove that and shake it. If it rattles then it is bad. Replace and you will be running again. If compressor is running then most likely compressor is bad. Check frost pattern on the evaporator in the freezer section. If it appears that compressor is running and the evaporator is a little cold and maybe even has a little frost on the top of it then compressor is insufficient,
Posted on May 15, 2010
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
522 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
