Question about Garden
Removing a front tire/rim (troy bilt lawn tractor) to replace it?
How do i remove a front tire/rim of a Troy Bilt Super Bronco lawn tractor? I need to replace the tire, tire is flat and coming off of the rim. It has a plastic cover over the center of the rim, where I might find a bolt or lug nut...but the plastic cover won't come off.
thanks for any help you can offer,
David
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    vincob
    • 718 Answers
    SOURCE: how to replace drive belt on troy bilt lawn
    Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
    http://www.jackssmallengines.com
    I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
    Posted on Sep 18, 2010
    roadtech7
    • 297 Answers
    SOURCE: HOW do I remove a front tire of a Troy Bilt Lawn
    On the front wheel is held on by an E clip, there is a large washer that a plastic cap is snapped onto. If you pry against the egde it will pop off, then remove the E-clip, a large standard blade screwdriver will work ( don't lose it, it will try to fly away), then slide the wheel off after you have jacked it up and supported the front of the tractor.
    Hope this helped
    Posted on Nov 11, 2010
    • 36 Answers
    SOURCE: I need to replace the blades on my Troy Bilt 46"
    If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
    Posted on Aug 18, 2011
    Need diagram to replace tension spring for drive belt
    Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
    My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
    Nov 03, 2015 | Garden
    Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
    Troy Bilt Deck belt Replacement - YouTube
    ? 11:46
    www.youtube.com/watch?v=w3SrErGTyoY
    Apr 1, 2014 - Uploaded by Murray Mayhem
    I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
    Jul 09, 2015 | Troy Garden
    What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
    go to troy blit and input model number, this will tell you what you need to know
    Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
    I have a troy bilt super bronco lawn mower tracter. i have a blow out and have to take the front left tire off.. I cant get the tire off. how do you remove the tire?
    Remove the center cap. Then there are 3 ways the wheels are held on. One is with an E-clip, remove with a straight screwdriver by inserting in gap between prongs and twist. Two is a snap ring that is removed with external snap ring pliers. Three is a cotter pin that is removed by straighting the ends and pulling out with pliers. Next remove the washer and pull off the wheel.
    I hope this is helpful for you.
    Aug 05, 2011 | Garden
    I have a 19 hp Troy Bilt Super Bronco with the
    sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
    May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    How do you remove the gears on a front wheel self propelled troy bilt push mower?
    Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
    Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
    I just punctured the front tire on my Troy Bilt Pony riding mower. where can i find a replacement tire?
    troy sells them but just put tire slime or, a similar product to seal the puncture; into the tire and, fill with air
    Oct 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Troy-bilt bronco riding lawn mower choke problem
    Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
    Sep 07, 2009 | Garden
    Garden Logo
    638 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
