Question about Dometic Rooftop RV Air Conditioner
I have a 92 terry 29' camper. I accidently connected 240v to it. Funny, I Know.Now, the coleman ac/htpump does not work . Did I Ruin the unit or can it be repaired? Also the 12v capacitor is out
  • 674 Answers
It's hard to say. You should probably start by checking your transformer. I don't think line voltage goes to the control board. If your transformer is OK then check out the other components (contactors or relays). Then check the windings on the fan motors and compressor motor. Give it a good visual inspection looking for anything that looks burnt and see if anything smells burnt. One question, did you turn it on or was it done before you got that far. If you didn't turn it on then maybe you'll just be looking at a transformer and you said the capacitor was out.
Posted on May 15, 2010
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
What refrigerant is in a Coleman 7300 Series AC Unit, on a 1995 Wilderness Camper?
This unit uses R-22. Here is a link to the service manual:
www.bryantrv.com/docs2/docs/rvp/rvp6789mech.pdf
Jul 17, 2015 | Coleman Heating & Cooling
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
I am looking at a 94 Coleman pop up camper. The
They are a closed system, so obviously it had/has a leak. You can get some AC guys that will retrofit it to allow for adding freon, but if it has a leak anyway, which will probably cost you a couple of hundred bucks to find out you have a leak that may not be evident until after you've already bought it, then leaks out again, and your back at square one. Depending on what size BTU's you want, you can pay anywhere from $500-$1000 + plus inside controls etc, if needed.
Jul 10, 2009 | Heating & Cooling
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
126 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
