Question about ViewSonic VX2235WM Monitor
Computer monitor says no signal - ViewSonic VX2235WM Monitor
  • 11,361 Answers
Try it on another PC, also check all the pins at both ends of the VAG cable. If it still does not work, then you may have to open it up and look for bad caps (leaking/bulging) in the power supply as shown in my pictures.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Posted on May 15, 2010
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Monitor no signal acer M1640
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
May 02, 2012 | Computers & Internet
Says No Signal but I clearly just pluggd it in and turned it on, and yes my computer is on
The "no signal" message is telling you there is no output from the computer. The output signal switches on the monitor, so if not there, check your cables and connections. If you have another monitor, try connecting it instead, and see if it works.This is an unusual problem, so keep trying. Connect the monitor to another computer, such as a laptop, and see if it works. If the monitor on another computer works, obviously it the first computer. If the first computer works with the second monitor, it's the first monitor.
Mar 31, 2010 | ViewSonic VA903B Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
When I turn on my computer I getting no signal to the monitor.
I connect my monitor to my computer and I recieve no signal but my computer screen work just the other day, this problem come about when I disconnected my monitor to view on another PC. And now I rec onnect it to my computer and I don't get any signal.
Dec 28, 2008 | Acer AL1916W 19" LCD Monitor
Monitor does not detect computer signal
you could need to update your driver.if you need help doing it get back to me.
Dec 06, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
ViewSonic VX2235WM Monitor Logo
310 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
